Ron62 Posted January 29, 2017 Share Posted January 29, 2017 I have a 83 Toyota Corolla wagon with a 3 speed Auto transmission that's having driveshaft vibration problems . I've replaced the extension housing bushing and seal but it didn't solve the problem. After installing the new bushing the driveshaft yoke still had too much back and forth play when I inserted into the housing ... Any help would be appreciated ? Ron .. Quote Link to comment Share on other sites More sharing options...
Maineah Posted January 30, 2017 Share Posted January 30, 2017 Well it is a Toyota but not a Toyota motor home. Quote Link to comment Share on other sites More sharing options...
WME Posted January 30, 2017 Share Posted January 30, 2017 Drop the drive shaft, check the u-joints, If its a 2 piece driveshaft check the carrier bearing. The seal and bushing have nothing to do with the fore and aft movement of the driveshaft. Quote Link to comment Share on other sites More sharing options...
