dolcecanto Posted October 4, 2016 Share Posted October 4, 2016 Has anyone sealed the upholstery to a metal door on a Sunrader. Ours is loose and I'd like to seal it before winter. Thank you. Quote Link to comment Share on other sites More sharing options...
linda s Posted October 5, 2016 Share Posted October 5, 2016 There are supposed to be automotive clips in there to hold in place. They must have broken off and you can't replace them without removing the fabric from a board it's mounted on. I would glue gun it. The glue is flexible so it should hold up to the vibration of the truck. if it does come loose it's easy to redo. Just be careful not to drip any into your window mechanism or lock. Only around the edge Linda S Quote Link to comment Share on other sites More sharing options...
dolcecanto Posted October 12, 2016 Author Share Posted October 12, 2016 Thank you! Quote Link to comment Share on other sites More sharing options...
