davidtan Posted October 2, 2016 Share Posted October 2, 2016 Put a 1000 watt inverter so no need for generator to run microwave..good times Quote Link to comment Share on other sites More sharing options...
hunkaman Posted October 3, 2016 Share Posted October 3, 2016 hello. please excuse my ignorance, are you saying the 1000 watt inverter obtains power from the 12 volt coach battery and then powers the microwave ? if i have described this correctly, does this process not drain the coach battery severely ? thank you in advance for educating me. joe from dover Quote Link to comment Share on other sites More sharing options...
WME Posted October 3, 2016 Share Posted October 3, 2016 Your basic description is correct. How does 100 amps at 12v sound?? Quote Link to comment Share on other sites More sharing options...
Nickyd Posted October 3, 2016 Share Posted October 3, 2016 Is the inverter Hooked up to some sort of house battery so you're not draining while parked Quote Link to comment Share on other sites More sharing options...
linda s Posted October 3, 2016 Share Posted October 3, 2016 53 minutes ago, Nickyd said: Is the inverter Hooked up to some sort of house battery so you're not draining while parked Yes you would only hook up an inverter to your house battery. Linda S Quote Link to comment Share on other sites More sharing options...
davidtan Posted October 7, 2016 Author Share Posted October 7, 2016 Yup...hooked up straight to house..i just got tired of pulling out the generator to warm up leftovers or turning on the oven...I tried it for 3 minutes on high , seemed to work fine. I think any longer and you would have to run the engine. I have a solar panel on top that charges the house but i think its broken ( it came with the rv).. Maybe worth checking to see how much to replace..fun times. Quote Link to comment Share on other sites More sharing options...
bicoastal eric Posted October 7, 2016 Share Posted October 7, 2016 Solar panels usually don't really break, maybe disconnected? I like your gang box setup, looks good. Personally I just put the left overs in a skillet for a few minutes. Quote Link to comment Share on other sites More sharing options...
