Movingcastle Posted September 21, 2016 Share Posted September 21, 2016 In my Toyota Dolphin 21' there seems to be a pretty serious leak creating a wetness in the carpet in front of the toilet close to the shower. I noticed it got a lot worse when I'm hooked up to a water line at a campsite. Please help diagnose this cause I'm worried it's going to eat away at the floor! Quote Link to comment Share on other sites More sharing options...
zulandio Posted September 22, 2016 Share Posted September 22, 2016 Sounds like a broken waterline somewhere if it's worse connected to water. Wouldn't explain the leak without hook up unless you always have water in the water tank with pump on. Quote Link to comment Share on other sites More sharing options...
Maineah Posted September 22, 2016 Share Posted September 22, 2016 I suspect the water heater they are prone to getting pin holes in the bottom with age and the water runs across the floor under the carpet when they do. Most domestic water is a good 20 psi or more above the on board pump it's all ways a good ideal to put water pressure regulators on a hose connection. Quote Link to comment Share on other sites More sharing options...
bicoastal eric Posted October 14, 2016 Share Posted October 14, 2016 Year? Floor layout? It will eat away your floor, fast. You don't notice the water pump running? My 1990 dolphin with rear bath had two leaks when I got it. One was at the bathroom sink where one of the lines attached to the faucet. And one under the shower pan toward the kitchen at a three way T connector. I have also had shower pans with cracks but it doesn't sound like that's your problem. Just follow the water my friend Quote Link to comment Share on other sites More sharing options...
