jjrbus Posted June 11, 2016 Share Posted June 11, 2016 Being a self taught expert on various adhesives I should pass along some tip's. With any adhesive proper prep is mandatory, so cover all areas you do not want to get adhesive on. Always start by waiting to put protective gloves on until you get going, it makes things easier! I prefer Nitrile gloves. Harbor Freight sells non powdered ones cheap, I keep baby powder next to the box and usually use it. Once the container of adhesive is opened take a large glop of it and place in your non dominant hand. Set down the container/applier and rub both hand's together. At this point it is time to run your non dominant had through your hair. Then with your dominant hand scratch your nose or ear if you prefer. NOw depending on experience and circumstances, you can go take a pee or pick up your $600 smart phone to answer a call Jim SW FL Quote Link to comment Share on other sites More sharing options...
WME Posted June 11, 2016 Share Posted June 11, 2016 silver-graphite anti-seize is worse, it will jump from your hands to most anywhere on its own. Quote Link to comment Share on other sites More sharing options...
jjrbus Posted June 11, 2016 Author Share Posted June 11, 2016 1 hour ago, WME said: silver-graphite anti-seize is worse, it will jump from your hands to most anywhere on its own. I plan on doing a short write up on lubricants, I should include antiseize and loctite. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted June 11, 2016 Share Posted June 11, 2016 CopperKote is best. It just looks like you've used an artificial tanning cream. Quote Link to comment Share on other sites More sharing options...
