AbleThought Posted January 3, 2016 Share Posted January 3, 2016 Hi, I recently acquired 83 Toyota Sunrader. I have never owned an RV in my life so if this question is dumb sorry in advance. There is a plug at the back on the outside passages side of the Sunrader that is draining water as I use the water. I am guessing it's some sort of overflow but I have no clue. Pics are below can anyone shed some light on what is happening here? Quote Link to comment Share on other sites More sharing options...
5Toyota Posted January 3, 2016 Share Posted January 3, 2016 that is a water heater drain cock. turn right to close it left to drain it I drain myn when not using it . that needs to be shut and the tank will fill with water . before you light it that looks the same as I have in my dolphin. turn gas tank on turn red nob to pilot. hold down the red knob and use a long lighter in the hole to the right THE one under the vent once lit hold down 30 secends to a minite let up pilot should stay lit turn red knob to on main burner should light with a roar. Quote Link to comment Share on other sites More sharing options...
AbleThought Posted January 3, 2016 Author Share Posted January 3, 2016 Ahh thank you thank you. quite helpful. that is a water heater drain cock. turn right to close it left to drain it I drain myn when not using it . that needs to be shut and the tank will fill with water . before you light it that looks the same as I have in my dolphin. turn gas tank on turn red nob to pilot. hold down the red knob and use a long lighter in the hole to the right THE one under the vent once lit hold down 30 secends to a minite let up pilot should stay lit turn red knob to on main burner should light with a roar. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted January 8, 2016 Share Posted January 8, 2016 that drain valve looks a little corroded to me. IS it shutting off completely? Quote Link to comment Share on other sites More sharing options...
