'90 Winebago Warrior Shower
The bottom shower pan and the seams in the shower walls are shaking apart. The screws are vibrating out of the pan. What can I replace them with that will stay in.
I tried putting white duct tape along the shower wall seams and it just fatigued in the corners. Are there other tapes of patching techniques that will work better?
Thanks Larry
I've had problems with gaps between the shower walls and the pan too; the back wall of the shower (next to bumper) is the most affected on mine—almost looks like the rear body of the camper is slowly pulling away from the rest.
I've had some success with running a good bead of caulk along the widening seam and then covering it with this sealer trim product. I'm not sure how permanent it will be, but it looks pretty decent, if you take your time. (Make sure the shower is very clean and dry before attempting for best adhesion.)
  • 4 weeks later...
