guitarlover519 Posted March 18, 2015 Share Posted March 18, 2015 So the generator was working perfectly until i winterized. I went to start it and nothing. No lights on the button. Trying to manual override outside doesn't work either. Quote Link to comment Share on other sites More sharing options...
WME Posted March 18, 2015 Share Posted March 18, 2015 Normally the Generator starts from the house battery, check and make sure its charged. Quote Link to comment Share on other sites More sharing options...
guitarlover519 Posted March 19, 2015 Author Share Posted March 19, 2015 House battery is fully charged Quote Link to comment Share on other sites More sharing options...
fred heath Posted March 19, 2015 Share Posted March 19, 2015 Check the contacts on both +&- battery connections. A bad ground to the chassis will cause this problem. You should have 2 , 5a fuses that twist out near the start switch. One controls the fuel pump, the other for the internal circuit board. Quote Link to comment Share on other sites More sharing options...
Maineah Posted March 19, 2015 Share Posted March 19, 2015 I have seen the generator ground strap bolted down to the bottom through the plywood relaying on the tightness of the bolt only to make contact. If the plywood dries out a bit and shrinks it leaves you with a loose bolt and a poor ground. Quote Link to comment Share on other sites More sharing options...
