washedlikeadish Posted March 13, 2015 Share Posted March 13, 2015 So.... RV repairman says our Onan Microlite 2.8 GENSET needs a new carb. Generator runs but has a pattern of fast then slow then fast then slow. Anything we can do about it instead of buying a new carb? We have it in our 1986 Toyota Odyssey we love! Quote Link to comment Share on other sites More sharing options...
Ace57 Posted March 13, 2015 Share Posted March 13, 2015 Try spraying some carb cleaner in it when it's running. Quote Link to comment Share on other sites More sharing options...
Milt Posted April 29, 2015 Share Posted April 29, 2015 (edited) Take the Carb off and soak it in carb cleaner over night, then use a air hose to blow out the holes, most of the time it's a sticky float from gum build up. any event really no need for a new one. Worked on all my motorcycles i ever had, should work for the Gen as well. Might need a new gasket is all, maybe not, depends on the condition. Edited April 29, 2015 by Milt Quote Link to comment Share on other sites More sharing options...
5Toyota Posted April 29, 2015 Share Posted April 29, 2015 seems none of those shop guys want to rebuild or don't know how to anymore just sell you a brand new one . seen the same problem with lawn mowers. only the old timers will rebuild it. shop kids don't care bill you the big money for a new one. Quote Link to comment Share on other sites More sharing options...
WME Posted April 29, 2015 Share Posted April 29, 2015 There are NO rebuild kits for Onan carbs. ONAN say buy a new one, not the local rv shop. Quote Link to comment Share on other sites More sharing options...
Maineah Posted April 29, 2015 Share Posted April 29, 2015 The carb has an " altitude" adjustment you may try tweaking that it's on the bottom of the carb there is only a small range of adjustment unless you kind of defeat it but that may help you smooth it out my guess it's too lean. There is a large screw don't disturb that is the governor speed adjust. Quote Link to comment Share on other sites More sharing options...
shibs Posted April 30, 2015 Share Posted April 30, 2015 my 2 hp Honda outboard has issues dying on me at WOT, some guys at the spoonplugger club suggested SEAFOAM, I have not tried it, but something you can try, I read good things about it. Quote Link to comment Share on other sites More sharing options...
