chefdave Posted November 4, 2014 Share Posted November 4, 2014 Hi can someone confirm if toyota part number 90942-020(58) or 68 is the correct wheel stud for a 1989 21ft dolphin with v6. could i use a stud off a 4runner of same year. Thanks dave Quote Link to comment Share on other sites More sharing options...
chefdave Posted November 4, 2014 Author Share Posted November 4, 2014 Dont ask how i snapped it. lol :-) :-) :-) Quote Link to comment Share on other sites More sharing options...
Skydancer2992 Posted November 4, 2014 Share Posted November 4, 2014 According to http://www.toyotapartszone.com/ and my VIN number (1991 Warrior, 90 chassis), the second number - 68 fits but not the first. Price $2.64 each. Quote Link to comment Share on other sites More sharing options...
chefdave Posted November 4, 2014 Author Share Posted November 4, 2014 Hi skydancer thanks for reply link has answered my questions. being in uk with search for 4 runner as my chassis with drw does not exist in europe. Thanks again dave Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted November 8, 2014 Share Posted November 8, 2014 if you take the old one to any decent autoparts house they can match it. Quote Link to comment Share on other sites More sharing options...
chefdave Posted November 8, 2014 Author Share Posted November 8, 2014 Hi dan minor prob with decent auto parts place is nearest is 120 miles away on roads which wind like a snake and go up down from sea level to 1500 ft like a roller coaster. not a good idea with a missing stud. So looking to buy off internet. Quote Link to comment Share on other sites More sharing options...
zero Posted November 9, 2014 Share Posted November 9, 2014 Hi can someone confirm if toyota part number 90942-020(58) or 68 is the correct wheel stud for a 1989 21ft dolphin with v6. could i use a stud off a 4runner of same year. Thanks dave You didn't mention front, or back, and if your front wheels match your dually rears. Toyota dually FF rears use studs that are 14 mm diameter (approx 1/2"). 4 Runners and minitrucks use studs that are 12 mm in diameter (approx 9/16"). Quote Link to comment Share on other sites More sharing options...
zero Posted November 9, 2014 Share Posted November 9, 2014 You didn't mention front, or back, and if your front wheels match your dually rears. Toyota dually FF rears use studs that are 14 mm diameter (approx 1/2"). 4 Runners and minitrucks use studs that are 12 mm in diameter (approx 9/16"). Excuse my dyslexia. I inverted those figures. RVs with FFs and 7.25" X 6 lug wheels use 14 mm studs that are approx 9/16" diameter. 4-Runners and light trucks use 12 mm studs (approx. 1/2"). Quote Link to comment Share on other sites More sharing options...
zero Posted November 9, 2014 Share Posted November 9, 2014 Hi can someone confirm if toyota part number 90942-020(58) or 68 is the correct wheel stud for a 1989 21ft dolphin with v6. could i use a stud off a 4runner of same year. Thanks dave 9094202058 is a 14 mm diameter stud for the front. 1 1/2" long. Local auto parts will probably carry a replacement with the Dorman brand. Part # 610338. NOT what a 4-Runner uses. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 9, 2014 Share Posted November 9, 2014 A 1989 Dolphin would have matching wheels, front and rear. I'll go out on a limb (since I don't know any better) and assume that the same studs are used front and rear. EDIT: Since that PN specifically mentions 'Front' I (again) assume that the rear is different. http://www.toyotapartsdirect.ca/p/TOYOTA__/BOLT--HUB-FOR-FRONT-AXLE-BOLT/47981735/9094202058.html Quote Link to comment Share on other sites More sharing options...
zero Posted November 9, 2014 Share Posted November 9, 2014 A 1989 Dolphin would have matching wheels, front and rear. I'll go out on a limb (since I don't know any better) and assume that the same studs are used front and rear. EDIT: Since that PN specifically mentions 'Front' I (again) assume that the rear is different. http://www.toyotapartsdirect.ca/p/TOYOTA__/BOLT--HUB-FOR-FRONT-AXLE-BOLT/47981735/9094202058.html Front and rear studs with matched 7.25" X 6 lug wheels are very different. Front are Dorman 610338 and rear are Dorman 610339. Fronts are only 1 1/2" long. Rear studs are 2 3/4" long. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 9, 2014 Share Posted November 9, 2014 1 assumption incorrect, 1 correct. Like playing Red or Black (almost) at roulette. http://www.dormanproducts.com/gsearch.aspx?type=keyword&origin=keyword&q=610-338 http://www.dormanproducts.com/gsearch.aspx?type=keyword&origin=keyword&q=610-339 Quote Link to comment Share on other sites More sharing options...
chefdave Posted November 10, 2014 Author Share Posted November 10, 2014 Hi just to clear up a few points. 1989 21ft dolphin ff rear axle. 6 stud wheel pattern. all wheels are interchangable. hope this helps everyone who has contributed to help me. Thanks dave Quote Link to comment Share on other sites More sharing options...
chefdave Posted November 10, 2014 Author Share Posted November 10, 2014 Hi should also add it has proper duellys. Quote Link to comment Share on other sites More sharing options...
zero Posted November 10, 2014 Share Posted November 10, 2014 Hi should also add it has proper duellys. You need the Dorman part #s that I posted. All your studs will be the equivalent of 9/16" diameter instead of the usual 1/2" found on other Toyota trucks and 4-Runners. In Metric speak that's 14 mm instead of 12 mm. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 10, 2014 Share Posted November 10, 2014 This assumes that Dorman sell it's products in the UK. http://www.dormanproducts.com/dispstatichtml.aspx?PageName=CI_international.html Quote Link to comment Share on other sites More sharing options...
chefdave Posted November 10, 2014 Author Share Posted November 10, 2014 Yes dorman will ship to uk. 10 studs £40 shipping. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 10, 2014 Share Posted November 10, 2014 Robbery!! They might sell TO the UK, but not IN the UK. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 11, 2014 Share Posted November 11, 2014 I'm not sure if this will do the job? But if it does, it's as fitted to the Dyna 150 and available locally in the UK. http://www.ebay.co.uk/itm/WHEEL-STUD-BOLT-LEXUS-LS460-LS600HL-LX470-LX570-TOYOTA-DYNA-LAND-CRUISER-100-200-/261636311437?pt=UK_Cars_Parts_Vehicles_Wheels_tyres_Trim_Nuts_ET&fits=Car+Make%3AToyota|Model%3ADyna+150&hash=item3ceabd498d 99p shipping, too. :) Quote Link to comment Share on other sites More sharing options...
chefdave Posted November 11, 2014 Author Share Posted November 11, 2014 Hi derek are measurments in mm. will compare to dorman on measurenents. IF the same whoopee. :-) Thanks dave Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 11, 2014 Share Posted November 11, 2014 Unfortunately, one of the critical dimensions isn't given: diameter of the knurl. But if all the others check out, you could investigate further. BTW, it seems the same stud is also used on some Landcruisers. http://afcparts.co.uk/0184-004-WHEEL-STUD-BOLT-LUG-NUT-OEM-90942-02077.html http://www.tojo4wdcentre.com.au/part-shop/view/627/141/landcruiser/landcruiser-uzj200-9-07-12-11/90942-02077-stud-wheel-bearing-hub-front-and-rear Quote Link to comment Share on other sites More sharing options...
linda s Posted November 11, 2014 Share Posted November 11, 2014 They don't appear to be the same stud. The right ones are still available from Toyota so if you would like I'd be happy to go to a local dealer and buy however many you want and ship them to you. Going to cost more than 2.64 a stud but ordering from toyotapartszone means paying their shipping charges too. Do you want new nuts too? Looks like the studs would be about 4 bucks each and shipping less than 25 dollars. Convert that to pounds and it sounds really cheap. Let me know Linda S Quote Link to comment Share on other sites More sharing options...
zero Posted November 11, 2014 Share Posted November 11, 2014 I'm not sure if this will do the job? But if it does, it's as fitted to the Dyna 150 and available locally in the UK. http://www.ebay.co.uk/itm/WHEEL-STUD-BOLT-LEXUS-LS460-LS600HL-LX470-LX570-TOYOTA-DYNA-LAND-CRUISER-100-200-/261636311437?pt=UK_Cars_Parts_Vehicles_Wheels_tyres_Trim_Nuts_ET&fits=Car+Make%3AToyota|Model%3ADyna+150&hash=item3ceabd498d 99p shipping, too. :) Does not look correct to me but you need the OD of the knurled section. It's not in the specs you gave. Quote Link to comment Share on other sites More sharing options...
zero Posted November 11, 2014 Share Posted November 11, 2014 Your Toyota calls for a stud with a total length of 1 1/2", not 2" like in the photo. If you cannot find a supplier where you live - why not just buy from the USA? I buy parts from Ireland and Great Britain often. Parts often get here in 4-5 days and shipping is often no more then when I buy from within the USA. Heck - if won't work for you - just have someone here send you the studs! I'll do it if you want. Quote Link to comment Share on other sites More sharing options...
chefdave Posted November 11, 2014 Author Share Posted November 11, 2014 Hi thanks to linda and jdemaris for offering to sent parts. for some strange reason shipping to uk for usa is very expensive but from australia very reasonable. no logic on it. Thanks dave Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 11, 2014 Share Posted November 11, 2014 Dave, have you tried running the Toyota PN by a UK Toyota Dealer. NOT the Dorman PN. Quote Link to comment Share on other sites More sharing options...
zero Posted November 11, 2014 Share Posted November 11, 2014 Hi thanks to linda and jdemaris for offering to sent parts. for some strange reason shipping to uk for usa is very expensive but from australia very reasonable. no logic on it. Thanks dave I buy a lot of parts from GB and Ireland and the parts usually gets here in 4-5 days. Last part I ordered cost $32 to ship and it weighed 20 lbs. Seems odd it's more in reverse. Is the USA making it difficult? Insured air mail to USA/Canada £20.00 White House Products LTD, Unit 3, Kelburn Business Park, Port Glasgow PA14 6TD, United Kingdom Quote Link to comment Share on other sites More sharing options...
chefdave Posted November 11, 2014 Author Share Posted November 11, 2014 I agree but £40 for a wheel stud is a rip off. might try a toyota dealer but dealers hate imports even grey imports from japan. even tried a 4wd supplier that supplies japanese thai and ozzie parts. answer a blunt no. used the toyota p/n. let you work out uk shambles on parts. now if i had a muscle car from us warehouses full of parts in uk or next day delivery from us. why are toyota parts difficult maybe they never break down. ????? Quote Link to comment Share on other sites More sharing options...
zero Posted November 11, 2014 Share Posted November 11, 2014 Why the heck don't you just buy the correct parts from Rock Auto like I do here in the USA? They have a British website catalog and have the right parts. http://www.rockauto.co.uk/ Quote Link to comment Share on other sites More sharing options...
zero Posted November 11, 2014 Share Posted November 11, 2014 Those studs are cheaper in the UK then here in the USA. $1.03 here in US and the equiv. of 98 cents in the UK Quote Link to comment Share on other sites More sharing options...
linda s Posted November 11, 2014 Share Posted November 11, 2014 Well Dave looks like the Rock Auto site is the best deal. My Toyota dealer has to order them so let me know ASAP. I didn't order yet. Good thing I checked the site before I went there. Linda Quote Link to comment Share on other sites More sharing options...
chefdave Posted April 23, 2019 Author Share Posted April 23, 2019 Hi long time since I've been on here. Update on wheel stud. Ordered a land cruiser wheel stud from a company in UK called rough trax. Think it cost me £5 with nut and postage. Took abit of wrangling to buy as they like to supply parts that fit first time. An American only supplied RV is not on there model option list. Agreed if it did not fit I would not return it. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 23, 2019 Share Posted April 23, 2019 So? Did it fit? Quote Link to comment Share on other sites More sharing options...
chefdave Posted April 23, 2019 Author Share Posted April 23, 2019 Yes a perfect match. Thread on stud matched nut. Quote Link to comment Share on other sites More sharing options...
