KEVIN Posted October 3, 2007 Share Posted October 3, 2007 hey guys,me again i have a 1986 dolphin 21ft., already prewired for a gen. my question is what size gen. would have come with this unit,also if i put a gen. (onan,etc.) in the compartment do these units have their own gas tank, or do i have to tie into the m/h gas tank ? thanks as always. Quote Link to comment Share on other sites More sharing options...
WME Posted October 4, 2007 Share Posted October 4, 2007 Onan 2800 microlite would be best. Some of this years had a Kohler 3000 or an Onan 3000. both are bigger in size than the Microlite. The generator would run off the main gas tank. If yours is a 22RE then you can draw fuel fron the EFI retrun line. If yours is a 22R then you will need a fitting installed. The idea of the return line on a RSE of special fitting is to keep you fron running the main tank dry and having to push you TOY home Quote Link to comment Share on other sites More sharing options...
