whyverne14 Posted August 1, 2014 Share Posted August 1, 2014 Since I drive for an auto parts store, I can get parts wholesale. As I look under the hood of the 1986 Toyota Pickup, I'm thinking maybe I should replace some of this stuff. Less things to worry about. Any ideas on parts I could replace just for the halibut? Already got new battery, alternator, wires, plugs, belts. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted August 1, 2014 Share Posted August 1, 2014 Have you worked your way through the Maintenance Schedule if the Owners Manual or FSM? Beyond that, I'd replace anything that's rubber! Also, the plastic chain guides can wear with pretty disastrous results. Quote Link to comment Share on other sites More sharing options...
zero Posted August 1, 2014 Share Posted August 1, 2014 I get parts at cost from NAPA since a friend of mine owns the store. But I usually get Toyota parts much cheaper from Rockauto when sold on close-outs. I stock up on many parts when dirt cheap and carry some with me. I don't tend to install them though unless needed. Different people worry about different things. I like having an extra electronic ignition parts on board as well as a new electric fuel pump. I also carry some good used parts, e.g. an extra computer, starter, etc. Quote Link to comment Share on other sites More sharing options...
WME Posted August 1, 2014 Share Posted August 1, 2014 Replace the hoses, especially the "hidden" hose under the alternator Quote Link to comment Share on other sites More sharing options...
Donnie Posted August 3, 2014 Share Posted August 3, 2014 Something that is often overlooked is changing your coolant...Some folks think that because it is protected adequately to -30........that this is OK.. not... When selecting a coolant...stick with the GOOD STUFF>......a lot of the less expensive coolant lacks the corrosion inhibitors of the brand name & although it will offer anti-freeze protection......it will not offer the protection that your engine needs......Donnie Quote Link to comment Share on other sites More sharing options...
whyverne14 Posted August 4, 2014 Author Share Posted August 4, 2014 Thanks everybuddy. My "things I'd like to do" list is nice and looong. Quote Link to comment Share on other sites More sharing options...
