water pump replacement on 77' 20r
nhcamper
Hi All,
I am replacing the water pump on my 77' Chinook this week and I am looking for any help to make this as painless as possible. I ordered a new Cardone water pump not a rebuild. I plan on replacing the belts at the same time any other parts I should replace to save myself a headake later on? The radiator is in good shape so I don't need to remove it if it is not nessecary to change the water pump.
Thanks for your help.
Tim
The shaft has been sloppy for a while and it finally gave out the other day. It sounded like a deisel just before it started leaking coolent out the bottom. I think it is a pretty straight forward RandR but I was just looking for some reassurance before I took it apart. I replaced the thermostat in the spring. I will post a reply on how the fix went Wen. or Thur. Thanks for the reply.
Tim
