traderbob3 Posted July 27, 2007 Share Posted July 27, 2007 RR Air Bag has slow leak, Does anyone have a temporary fix short of replacement. Thanks from Trader Bob3 Quote Link to comment Share on other sites More sharing options...
futar Posted July 28, 2007 Share Posted July 28, 2007 A few including me have tried the tire sealant without any luck. It doesn't move around like a tire so the sealant doesn't get to the leak. They crack over time and it isn't worth trying to patch. I personally don't like the airbags with the exception of the heavy duty ones on the Sunraders that go right over the axle. I don't like the bounce. The other airbag afterfits like on the Winnebagos are crappola. I just put a full length booster spring on for under $40. One I did I had to unloosen the shackle to slide it in. This latest one I got goes right over the shackle. Unfortunately you have to remove the clamps on the spring from the old airbags to fit it in. That means cutting the old airbag out. No loss as far as I'm concerned. Good luck with whatever you do. Quote Link to comment Share on other sites More sharing options...
WME Posted July 29, 2007 Share Posted July 29, 2007 Make up a batch of soapy water and check the lines and fitings. WME RR Air Bag has slow leak, Does anyone have a temporary fix short ofreplacement. Thanks from Trader Bob3 Quote Link to comment Share on other sites More sharing options...
