markb Posted June 28, 2007 Share Posted June 28, 2007 The '86 Sunrader 4x4 that belongs to Greg evidently has 15" wheels. Is the full floating axle a Toyota? If so, where did you find 15" dual wheels to fit? I have a '90 Toyota Odyssey factory 4x4. It did not come with a full floating axle, but I have acquired a one- ton dually Toyota axle that I intend to install. The wheels are 14" and I would like to go 15". Any ideas, suggestions? If I have to stay with 14" on the Toyota axle, do you know of a 14" wheel to fit the front that is a stock type wheel and not a white spoke? Also, if I have to stay with 14" what is the largest size applicable in a rugged tread? Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted June 29, 2007 Share Posted June 29, 2007 The axle is toyota. I checked with toyota just the other day about the wheels and they are not stock. My guess is they were a special build. One thing with mine is the offsets are not the same, Can't remember the exact inches but one pair is say 9 3/4 in and the other pair is 9 3/8 in. I put the shorter offset on the inside and the longer on the outside. I was also told by a toyota parts guy that Chevy 6 bolt rims will bolt on. A place several of us have considered is called stockton wheel. http://www.stocktonwheel.com/ they can build the wheels. If enough of us get together maybe we could get a discount. I want a spare as presently I only have a front spare. Quote Link to comment Share on other sites More sharing options...
nolan Posted June 30, 2007 Share Posted June 30, 2007 . I was also told by a toyota parts guy that Chevy 6 bolt rims will bolt on. Hey Greg, The early Chevy 1/2ton 4x4 6 lug wheels are the same as the stock Toyota 4x4 6 lug pattern, like yours has on the front, the rear 1 ton floater axle 6 lug wheel is a different critter all together, and only used on that application as far as I know, BUT!! I have seen many of the earlier Datsun motorhomes with a dual wheel floater axle that looks like it uses the same unique 6 lug pattern as the Toyota does, never looked any further though to see if by chance they were the same bolt pattern, same wheel, or a 14" or 15" size, might be a possible source for Toy owners looking for wheels if by chance they were the same. Quote Link to comment Share on other sites More sharing options...
markb Posted June 30, 2007 Author Share Posted June 30, 2007 Thanks for the info. I will proceed with making the 14" wheel into a 15". I have a machine shop locally that can do the job. So they say. I'll let you know how they come out. Quote Link to comment Share on other sites More sharing options...
