ecogenie Posted June 7, 2007 Share Posted June 7, 2007 (edited) I HAVE A USED 1991 TOYOTA UHAUL 1 TON BOX TRUCK. CAN YOU TELL IF THERE IS A GEAR BOX OR A RACK AND PION ON THIS. I WAS TOLD THAT THE RACK AND PION HAS IS ABOUT TO GO OUT IN IT. CALLED NAPA HERE IN FLORIDA AND THEY SAID THAT THERE IS NO RACK AND PINON IN IT. DOES ANYONE KNOW WHAT IS IN IT? I NEED IT CHANGED OUT WHATEVER IT IS BECAUSE THERE IS A LOUD CLANKING SOUND AS YOU GIVE IT GAS AND WHEN YOU TAKE YOUR FOOT OFF OF THE GAS. WHAT SHOULD I PAY FOR ONE OF THESE GEAR BOXES AND HOW DO I CHANGE IT OUT? I SURE WOULD APPRECIATED ANYONES IMPUT ON THIS. THANKS SO MUCH FOR YOUR HELP!!! Edited June 7, 2007 by ecogenie Quote Link to comment Share on other sites More sharing options...
jim Posted June 7, 2007 Share Posted June 7, 2007 If you are talking about the steering it is not rack and pinion but steering box. I suspect since you talk about clank when accel or decel you mean pinion as in the rear differential. This could be expensive , best to change the whole ring and pinion assy . But first check it could just be a bad u joint. Quote Link to comment Share on other sites More sharing options...
