zero Posted December 9, 2012 Share Posted December 9, 2012 I've read on several Toyota forums including this one - that the center section on the FF axle is the same as the 1/2 ton axle. NOPE. Mabye for a later truck but not on a 1978. I just found out the hard way. Seems Toyota trucks went through a major change between 1978 and 1979. Two very different trucks. Something I had not anticipated. Maybe Toyota was gearing up to introduce 4WD and thus the radical changes. First thing I noticed is that the 1978 driveshaft will not bolt up the pinion flange on the later FF axle. I then figured I'd just swap pinion flanges. NOPE. Can't swap them. Different spline count. I then noticed that even the universal joints in the driveshaft are all different. Later ones are bigger as are the bolts. I was then thinking about making a custom driveshaft and getting it balanced (not really wanting to though). I then decided to pull the rear axles on both and compare the end splines to see if they match. Yes they do - and thank heavens. So it seems I can take the complete center section out of the 1978 1/2 ton axle and swap it into the 1987 FF axle assembly assuming the 10 bolt holes line up. At least I know they both use the same axle spline count and OD. I suspect if this Toyota was a 1979 instead of a 1978, all this would be MUCH easier. Quote Link to comment Share on other sites More sharing options...
