siskiou Posted July 20, 2012 Share Posted July 20, 2012 Was able to upload/attach pictures earlier today, but now it fails each time, and says uploading is not allowed. What could be the reason? Quote Link to comment Share on other sites More sharing options...
waiter Posted July 20, 2012 Share Posted July 20, 2012 Check to make sure your using the "Full Editor". The normal default editor doesn't allow uploads. (Look just below your editing window. Theres a button that says "Save Changes" just to the right is a "Use Full editor" button. Also, Make sure your logged in (obviously, but sometimes overlooked) make sure the file your attempting to upload is correct format for what your doing (i.e. PDFs, JPGs, PNGs used in proper areas. read carefully the warning messages, they usually give a hint what it doesn't like As a courtesy to bandwidth, I always attempt to re-size photos to maybe no larger that 3 or 4 inches, and if able, compress them down to less than 100 DPI Try to keep JPGs and PNGs down below 100k filesize. If someone really wants to see a high resolution, they can send you an e-mail and request it.. John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
