twoblocked Posted November 28, 2011 Share Posted November 28, 2011 I've been following a lot of threads on this subject. There is much misinformation out there. Maybe we could start with the following PDF attachments: the Toyota FSM and the Toyota Lexus Training Manual. (it refers to our Trucks also) Granted, this is for the technically minded.... Toyota FSM-LSP&BV.pdf Toyota Training Manual-LSPV.pdf Quote Link to comment Share on other sites More sharing options...
bajadulce Posted November 28, 2011 Share Posted November 28, 2011 thnx for uploading. Ya, quite techinical, but good info. Look forward to reading more input from members on this subject especially those of us with airbags. Quote Link to comment Share on other sites More sharing options...
Maineah Posted November 28, 2011 Share Posted November 28, 2011 The MH is all ways at max load plus some no matter what. I'm going to say that the chance of locking the rear wheels is all most nill even with full pressure so it's best to have all the breaking you can get back there. Unlike a car with the weight transfer forward with the rear lifting the MH will not lift at the back because of the weight so there is a lot more breaking going on in the back of a loaded truck then in a normal car or and unloaded pickup. Shortly after I got mine I by passed the valve I will say that the results were not dramatic it still took 90% more then a dime to stop it. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 28, 2011 Share Posted November 28, 2011 Did you manage to find the Training Manual online? Thanks for posting the section. I'd like to read other sections, if they're available somewhere. Quote Link to comment Share on other sites More sharing options...
twoblocked Posted November 28, 2011 Author Share Posted November 28, 2011 Yes, the complete Training Manual is available online at Kevin Sullivan's Autoshop 101 web site. http://www.autoshop101.com/autoshop15.html Fascinating bedtime reading...... Did you manage to find the Training Manual online? Thanks for posting the section. I'd like to read other sections, if they're available somewhere. Quote Link to comment Share on other sites More sharing options...
twoblocked Posted November 28, 2011 Author Share Posted November 28, 2011 >>The MH is all ways at max load.... Agreed. My Itasca has 2,000# on the front and 4,000# on the rear. Front disc brakes, rear drums. >>I'm going to say that the chance of locking the rear wheels is all most nill Again agreed. (icy conditions exempted) >> ... the MH will not lift at the back because of the weight so there is a lot more breaking going on in the back of a loaded truck.... I'm having difficulty getting my head around this statement. Any vehicle in heavy braking conditions moves weight forward due to inertia. Just because our MH have more weight in the back does not mean this is where the majority of the braking power should be. I believe DRAGGING (rear wheel bias) the duals is a less efficient way to stop than the judicious use of HIGHER braking pressure in front (front wheel bias) and LOWER braking pressure in the rear. A properly adjusted LSPV assures this. This is what adjusting the shackle on the LSVP spring does for my braking; Pics show the adjustment changes. "Maximum Rear Braking" adjustment feels like most of the braking is being done by the rear wheels. There is no diving of the front end under any conditions. "Balanced Frt-Rear" adjustment was the original position when I got the MH. The front of the MH dives under hard braking. It feel like a normal vehicle, both front and rear are working. "Minimum Rear Braking" adjustment causes the front to severely dive under hard braking. I don't think the rear drums are doing much at all. Quote Link to comment Share on other sites More sharing options...
bajadulce Posted November 28, 2011 Share Posted November 28, 2011 I believe DRAGGING (rear wheel bias) the duals is a less efficient way to stop than the judicious use of HIGHER braking pressure in front (front wheel bias) and LOWER braking pressure in the rear. A properly adjusted LSPV assures this.So the best braking would be a balanced Frnt-Rear adjustment such as your second picture or a more maxed rear? Maineah of course bypassing his entirely. WME brought up a good point in that air bags negate the intended purpose of this valve (truck sits at designated level based on air pressure in bags not spring plate to frame displacement). In my particular scenario, the camper comes off the rig and thus the truck has 2 distinct loads (varying loads is exactly what this valve is designed for). However with airbags, it was suggested the setup be modified so that it has 2 quick settings; one for load (either camper on or w/work payload) + one for empty truck (camper off/no payload) which seems like a great idea. If not, I guess the easiest solution would be to find a middle ground for this scenario? A bypassed or Max setting valve would prob be Ok for the full payload and most RV's, it would probably not be so great for an empty truck w/ no camper. Quote Link to comment Share on other sites More sharing options...
twoblocked Posted November 28, 2011 Author Share Posted November 28, 2011 (edited) I don't see any problem with increasing rear wheel bias in our rigs due to the constant loading. The issue is when the LSPV is eliminated entirely from the braking circuit. Disc brakes by their design require higher fluid pressure to operate as compared to a drum brake. The reason being the pads in the calipers clamp the rotor, more stopping power requires higher and higher pressures. A drum brake is "self energising". This means that when the brake shoe is pushed into the drum, the rotational force actually pulls the shoes more tightly against the drum. I've read references that stated a caliper/disc brake requires two to three times the fluid pressure of a comparable drum. So what this means is by eliminating the LSPV you have equalized the front/rear braking pressures in the system and the rear drums are exerting a larger braking force than the front discs. I personally feel you have just negated a substantial portion of your braking power by doing this. I have nothing but empirical evidence to back me up here (my own) so if I am off base, I'm listening. WME's point is spot on. When you change the pressure in your air springs, the LSPV is also re-adjusted automagically. In your case of light and heavy loads I think the coolest solution would be an adjustable proportional valve to change the rear brake bias when needed. The gear heads do it all the time. Most eliminate the LSVP (be sure to cap the front brake sensing circuit also, it's the second line coming from forward into the LSPV) and put a knob operated adjustable proportional valve up under the hood, near the Master Cylinder. You could fine tune for both scenarios. So the best braking would be a balanced Frnt-Rear adjustment such as your second picture or a more maxed rear? Maineah of course bypassing his entirely. WME brought up a good point in that air bags negate the intended purpose of this valve (truck sits at designated level based on air pressure in bags not spring plate to frame displacement). In my particular scenario, the camper comes off the rig and thus the truck has 2 distinct loads (varying loads is exactly what this valve is designed for). However with airbags, it was suggested the setup be modified so that it has 2 quick settings; one for load (either camper on or w/work payload) + one for empty truck (camper off/no payload) which seems like a great idea. If not, I guess the easiest solution would be to find a middle ground for this scenario? A bypassed or Max setting valve would prob be Ok for the full payload and most RV's, it would probably not be so great for an empty truck w/ no camper. Edited November 29, 2011 by twoblocked Quote Link to comment Share on other sites More sharing options...
85mirage Posted November 28, 2011 Share Posted November 28, 2011 I love the picts. I had my valve adjusted to more in the rear awhile ago. I think it needs it again,can this be?. But i never knew what exactly was being adjusted. Picts make easy sense. I think my MH was adjusted like the first pic. Made MH stop a lot quicker! Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 29, 2011 Share Posted November 29, 2011 Thanks. Always being nosy, I clicked around and came across the following, listed as being for instructors! http://www.autoshop1...autoshop31.html I'll let you know if I find anything else. Yes, the complete Training Manual is available online at Kevin Sullivan's Autoshop 101 web site. http://www.autoshop1...autoshop15.html Fascinating bedtime reading...... Quote Link to comment Share on other sites More sharing options...
twoblocked Posted November 29, 2011 Author Share Posted November 29, 2011 Yes, this can be. As one increases rear braking pressures, there is additional wear on the rear brake shoes. This causes them to wear prematurely. You could be experiencing rear brake shoe wear. Or simply out of adjustment brake shoes. Anecdotal evidence from one gear head poster on another blog was that after he increased rear braking bias he wore out rear brake shoes at a rate of 2:1 (two pairs of rear shoes for every one set of front pads). Before he increased rear bias he was wearing out front disc pads at the rate of 2:1. (Two pair of front pads for every pair of rear shoes) Makes sense. It's the price of admission for jacking up rear bias. I think it needs it again,can this be? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 29, 2011 Share Posted November 29, 2011 I don't have a problem with brake pads or shoes wearing out, as long as they're providing useful stopping effort in return. I'd rather pay for pads/shoes than bodywork (or funeral expenses)! Quote Link to comment Share on other sites More sharing options...
85mirage Posted November 30, 2011 Share Posted November 30, 2011 Yes, this can be. As one increases rear braking pressures, there is additional wear on the rear brake shoes. This causes them to wear prematurely. You could be experiencing rear brake shoe wear. Or simply out of adjustment brake shoes. thanks i'll check rear pads, As the rear pads wear down do the nuts on the valve move down causing more front pressure? and need to readjust vavle after new pads? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 30, 2011 Share Posted November 30, 2011 Brake shoe wear (or installing new shoes) will not affect the valve. Changing your static ride height will require the valve to be adjusted. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 30, 2011 Share Posted November 30, 2011 ... However with airbags, it was suggested the setup be modified so that it has 2 quick settings; one for load (either camper on or w/work payload) + one for empty truck (camper off/no payload) which seems like a great idea. If not, I guess the easiest solution would be to find a middle ground for this scenario? A bypassed or Max setting valve would prob be Ok for the full payload and most RV's, it would probably not be so great for an empty truck w/ no camper. I think that if I was in your position, I'd load the camper on (full of supplies as if you were leaveing for Baja) and adjust the rod so that the valve is fully open. Then remove the camper and check that the valve position has now changed. Then take it out on a quiet road and stomp on the brakes and see if the rear brakes lock up before the front. This would not be good. A sure recipe for the truck to swap ends. But the bottom line is that you're going to have to accept that the rear is going to have to ride at least a bit lower with the camper on, even if your air springs are able to lift it back to 'Empty' height. The valve isn't particularly 'intelligent'. It has only 1 source of information. Your new air springs can very easily fool it. Quote Link to comment Share on other sites More sharing options...
Vanman Posted December 3, 2011 Share Posted December 3, 2011 Oh boy !! Reading brake08.pdf made me realize for sure what I've been thinking about the rear brakes. I have watched the body rise/fall as I varied the pressure in the air bags. As the axel does not move the valve adjustment must surely change. Not only do we have a whole lotta weight on these rigs but we also have much much more overhang beyond the rear axel than Toyota designed for. I don't think I'm getting much from the rears now, braking while backing downhill is a joke , the fronts lock easily and just slide. I have learned to apply the rears with the hand brake to get it to stop, now I see why. so I'm gonna set that thing to perment max braking and see how well that works. vanman Quote Link to comment Share on other sites More sharing options...
Derek up North Posted December 3, 2011 Share Posted December 3, 2011 ... braking while backing downhill is a joke , the fronts lock easily and just slide. Particularly 'fun' if you happen to have a trailer hooked up. Speaking from personal experience, though not with a Toyota motorhome involved. Somehow I managed to not jack-knife! Some praying was involved! Quote Link to comment Share on other sites More sharing options...
linda s Posted May 28, 2012 Share Posted May 28, 2012 Just finished doing the adjustment on mine. Unfortunately mine does not have screws to adjust top and bottom. On mine I had to remove the bar and unscrew the whole top unit and them reinstall the bar. haven't check the brakes yet but I'll check back and tell you the difference. Was down pretty low so the front brakes have been taking the most wear. Back should be like new LS >>The MH is all ways at max load.... Agreed. My Itasca has 2,000# on the front and 4,000# on the rear. Front disc brakes, rear drums. >>I'm going to say that the chance of locking the rear wheels is all most nill Again agreed. (icy conditions exempted) >> ... the MH will not lift at the back because of the weight so there is a lot more breaking going on in the back of a loaded truck.... I'm having difficulty getting my head around this statement. Any vehicle in heavy braking conditions moves weight forward due to inertia. Just because our MH have more weight in the back does not mean this is where the majority of the braking power should be. I believe DRAGGING (rear wheel bias) the duals is a less efficient way to stop than the judicious use of HIGHER braking pressure in front (front wheel bias) and LOWER braking pressure in the rear. A properly adjusted LSPV assures this. This is what adjusting the shackle on the LSVP spring does for my braking; Pics show the adjustment changes. "Maximum Rear Braking" adjustment feels like most of the braking is being done by the rear wheels. There is no diving of the front end under any conditions. "Balanced Frt-Rear" adjustment was the original position when I got the MH. The front of the MH dives under hard braking. It feel like a normal vehicle, both front and rear are working. "Minimum Rear Braking" adjustment causes the front to severely dive under hard braking. I don't think the rear drums are doing much at all. Quote Link to comment Share on other sites More sharing options...
linda s Posted June 23, 2012 Share Posted June 23, 2012 Just finished doing the adjustment on mine. Unfortunately mine does not have screws to adjust top and bottom. On mine I had to remove the bar and unscrew the whole top unit and them reinstall the bar. haven't check the brakes yet but I'll check back and tell you the difference. Was down pretty low so the front brakes have been taking the most wear. Back should be like new LS So here is how my adjustment worked out. Had no effect what so ever. Just got back from a long trip and on some pretty rough roads. I noticed absolutely no difference in the braking. Whats up? Quote Link to comment Share on other sites More sharing options...
WME Posted June 27, 2012 Share Posted June 27, 2012 Just remove the arm from the adjustment bolt and tie the arm to the frame. If still no change, then you may have a bad regulator. Quote Link to comment Share on other sites More sharing options...
bufbooth Posted August 15, 2012 Share Posted August 15, 2012 I was just reading over my 1990 Toyota Factory Truck repair manual about Load Sensing Proportionging level adjustment and it states that in additon to adjusting the height of the lever that the valve body itself can be raised or lowered and shows a diagram of the valve body and appear to be a bolt or two in the middle of the body that when loosened allows the valve body to move up or down. I am going to give this a try in the next day or two. Quote Link to comment Share on other sites More sharing options...
linda s Posted August 15, 2012 Share Posted August 15, 2012 I was just reading over my 1990 Toyota Factory Truck repair manual about Load Sensing Proportionging level adjustment and it states that in additon to adjusting the height of the lever that the valve body itself can be raised or lowered and shows a diagram of the valve body and appear to be a bolt or two in the middle of the body that when loosened allows the valve body to move up or down. I am going to give this a try in the next day or two. Those factory service manuals are just too large for my old computer to handle.I would be eternally grateful if you could post some pics from it so I could see if I can adjust mine some more. Just the proportioning valve adjustment didn't really help on mine Linda S Quote Link to comment Share on other sites More sharing options...
linda s Posted August 15, 2012 Share Posted August 15, 2012 And that is exactly what I would like to do. I would rather not take the thing apart if I can. adjust it more some other way LS Quote Link to comment Share on other sites More sharing options...
Derek up North Posted August 15, 2012 Share Posted August 15, 2012 Without benefit of seeing the FSM section in question I'm only 'guessing' (which I don't like doing). But it sounds as though doing this adjustment won't accomplish anything IF you've disconnected the linkage and secured it in the fully 'Up' position. It sounds like the additional mounting holes are there in case the rod/linkage won't adjust enough while still connected. Quote Link to comment Share on other sites More sharing options...
Maineah Posted August 15, 2012 Share Posted August 15, 2012 Ok here is the deal on rear truck brakes. Some large trucks (dump trucks etc.) have no front wheel breaks when you place most of the weight in the rear there is not nearly as much weight shift to the front it does not lift. A Toyota MH is all ways weighted to the rear it needs all the rear brakes you can give it under any circumstance . Backing up with drum breaks will be poor breaking because of the design of drum breaks they are what is called self energizing meaning the forward motion help apply them this does not happen in reverse. If you decide to adjust the proportioning valve adjust it for absolute max load because that is what it is. Quote Link to comment Share on other sites More sharing options...
linda s Posted August 16, 2012 Share Posted August 16, 2012 Ok here is the deal on rear truck brakes. Some large trucks (dump trucks etc.) have no front wheel breaks when you place most of the weight in the rear there is not nearly as much weight shift to the front it does not lift. A Toyota MH is all ways weighted to the rear it needs all the rear brakes you can give it under any circumstance . Backing up with drum breaks will be poor breaking because of the design of drum breaks they are what is called self energizing meaning the forward motion help apply them this does not happen in reverse. If you decide to adjust the proportioning valve adjust it for absolute max load because that is what it is. I know that. I was just interested in a possible way to adjust the valve directly because adjusting the thingy that sticks out didn't do the trick. Linda S Quote Link to comment Share on other sites More sharing options...
Derek up North Posted August 16, 2012 Share Posted August 16, 2012 Perhaps (?) your valve is seized. Quote Link to comment Share on other sites More sharing options...
linda s Posted August 16, 2012 Share Posted August 16, 2012 Perhaps (?) your valve is seized. So sombody tell me how to unseize it. Linda S Quote Link to comment Share on other sites More sharing options...
Derek up North Posted August 16, 2012 Share Posted August 16, 2012 I've never been 'inside' one, so hard to advise. With the rod disconnected, did the lever seem to move freely? Also, I seem to have read people who have simply removed the valve completely and hook the brake lines directly. I won't say if this is safe to do as I'm not sure if the valve performs a secondary function. Quote Link to comment Share on other sites More sharing options...
linda s Posted August 16, 2012 Share Posted August 16, 2012 I've never been 'inside' one, so hard to advise. With the rod disconnected, did the lever seem to move freely? Also, I seem to have read people who have simply removed the valve completely and hook the brake lines directly. I won't say if this is safe to do as I'm not sure if the valve performs a secondary function. Thanks Derek for at least responding. Guess I'm just going to have to buy a factory service manual on ebay or something. Probably should have one anyway. I think I saw something on yotatech about removing it. Never done brake lines but can't be too hard. Linda Quote Link to comment Share on other sites More sharing options...
Derek up North Posted August 16, 2012 Share Posted August 16, 2012 I doubt you'll find anything in an EBay FSM that's different from Post #1. Quote Link to comment Share on other sites More sharing options...
linda s Posted August 16, 2012 Share Posted August 16, 2012 I doubt you'll find anything in an EBay FSM that's different from Post #1. Computer is messed up. Too big to download. That's why I asked if I could just get a couple of pages of it. I'm better with paper anyway. On the ground next to me when I'm working. Linda Quote Link to comment Share on other sites More sharing options...
Derek up North Posted August 16, 2012 Share Posted August 16, 2012 Would your computer handle the files better if I sent them as attachments in an email? Quote Link to comment Share on other sites More sharing options...
Maineah Posted August 17, 2012 Share Posted August 17, 2012 The entire ideal behind the valve was for the pickups the factory did not build MH's when the truck was unloaded it reduced the break pressure so that the rears did not lock up they were designed to carry weight so the rears on the pickup had a greater breaking force (drums vers. disks) So the bottom line it is of no use on a Toyota MH because there is no way they will lock up. It is way over weight.and does not have enough sweep area or cylinder size. It will not ware the shoes any more then having it it's all ready trying the hardest it can to stop the *&^% thing because the valve is all ready at the highest weight setting unless you jack the rear up with air bags. My Nova Star has 9 leaf spring packs it does not sit level on flat ground the rear is higher it has no valve (any more) the rear breaks do not lockup it does stop a touch better but still is no prize. The brakes are over taxed it is what it is. Quote Link to comment Share on other sites More sharing options...
haffcke Posted October 27, 2012 Share Posted October 27, 2012 well I'm confused, will it do any good to adjust the bar shackle as in twoblock's top picture, or just wasting time, during panic breaking the front wheels lockup, and if its raining out forget about it, can't stop period, new shoes, turned drums rear, new pads rotors front, the only way i can lock up rears is with e-brake, not looking for lockup but would like to feel like I'm getting a little help from the rear, one thing i did notice last week on 1400 mile trip, i have always run with air bags full 90psi and tried this trip at 60psi just to feel the diff. in ride and i think the rears held a little better, could be my imagination, i was paying specif attention to breaks due to just having them done, anyways back to my original question, is the consensus here that i should or should not adjust the bar shackle to the proportioning valve? Quote Link to comment Share on other sites More sharing options...
