DorisTheDolphin Posted October 4, 2017 Share Posted October 4, 2017 Also, how do you clean connections? BTW, you guys are awesome! Thank you. Quote Link to comment Share on other sites More sharing options...
WME Posted October 5, 2017 Share Posted October 5, 2017 OK confusion on my part. One post you said the motor started and ran for 3 min, then slowed down and stopped. Then you said it squealed and then ran for 5 min.. Have you ran it multiple times?? or what is it doing. First is bad fan motor/weak battery. Second is bad fan motor Most of the contacts are sealed. But the ground is usually a screw some where to the chassis and the positive is a bolt connector. Find them and redo them. A voltmeter is real handy about this point, it will let you check the voltages through out the entire system and make it all good. Point being when I got my Escaper the isolator voltage was 14v + , the house battery voltage was under 11.5v. The P/O had spliced wire to many places and did a poor job. Replace all the battery charge wire mess and ended up wilt 13.8v at the battery. Low voltage will make a heater run bad or not at all. Quote Link to comment Share on other sites More sharing options...
