futar Posted October 15, 2006 Share Posted October 15, 2006 I have a 91 Winny with a model 6332 32amp Magnetek power supply. I feel it is putting out too high a DC voltage (18v). I don't have a manual on it. I can't get a response from Magnetek and you can forget Winnebago. Any one have a manual or schematic or??? Thanks Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted October 15, 2006 Share Posted October 15, 2006 There are some descriptions and shematics in the gallery, here are direct links http://toyotamotorhomes.com/forum2/uploads...50_56_24605.pdf http://toyotamotorhomes.com/forum2/uploads...50_56_44811.pdf http://toyotamotorhomes.com/forum2/uploads...50_56_13758.pdf This last link (below) is for the direct upgrade replacement for the 6300 series. I put one in as my 6300 voltage was all over the place and the charger killed my battery. The 6300 also puts a lot of ac voltage into the dc side due to its design and that killed some 12 volt dc electronic gear. Also the 6300 battery charger is a piece of ancient junk, the new 7300ru has a much better charger. I bought my 7300ru at www.campingworld.com Its really a nice unit and easy to replace. Its also rated at 55amps. http://toyotamotorhomes.com/forum2/uploads...0_56_115938.pdf Quote Link to comment Share on other sites More sharing options...
Thin Lizzy Posted February 16, 2007 Share Posted February 16, 2007 There are some descriptions and shematics in the gallery, here are direct links http://toyotamotorhomes.com/forum2/uploads...50_56_24605.pdf http://toyotamotorhomes.com/forum2/uploads...50_56_44811.pdf http://toyotamotorhomes.com/forum2/uploads...50_56_13758.pdf This last link (below) is for the direct upgrade replacement for the 6300 series. I put one in as my 6300 voltage was all over the place and the charger killed my battery. The 6300 also puts a lot of ac voltage into the dc side due to its design and that killed some 12 volt dc electronic gear. Also the 6300 battery charger is a piece of ancient junk, the new 7300ru has a much better charger. I bought my 7300ru at www.campingworld.com Its really a nice unit and easy to replace. Its also rated at 55amps. http://toyotamotorhomes.com/forum2/uploads...0_56_115938.pdf Hi, Could you please repost those pdf's? I have just purchased a 1991 Winnebago and would like to have this info. Thanks. Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted February 19, 2007 Share Posted February 19, 2007 Here is the main link to the gallery folder where they are. You should be able to get them all there, if you have a problem PM me. As of right now I was able to download them with no problems. The links in the previous posts went bad as I had to re upload the files due to a gallery problem. http://www.toyotamotorhome.org/forums/inde...q=sc&cat=56 Quote Link to comment Share on other sites More sharing options...
futar Posted February 25, 2007 Author Share Posted February 25, 2007 I forgot to reply. I did the upgrade and it is fantasmagorical. It's quiet and I can charge my cell phone now. The best price was here in Orygone at RV Parts Outlet. https://www.rvpartsoutlet.com/newstore/nojava/index.cfm Quote Link to comment Share on other sites More sharing options...
