ynkedad Posted December 1, 2010 Share Posted December 1, 2010 (edited) I had the awning up the other day (drying after a washing) on our 91 Dolphin, when apparently a strong enough wind came by and tore it up, while I was out front working in the yard. The lower bracket that holds the track closest to the passenger door, was pulled out (basically ripped off the camper, lag screws and all). This apparently allowed the whole thing to fold over and rip the awning right off the roller. Anyway, I need to repair the siding. It's only a small area that was pulled away and ripped a bit (maybe 3"x3" total) What would I use? Fiberglass??. Also, what could I use to repair the wood behind the siding. As you can imagine, when the lag screws were pulled out, it did a bit of damage to the wood. I'd like to have the awning repaired and put it back on, so the wood (or fixed area of wood) would have to be strong enough to put lag screws into it and hold it. Thanks guys/gals.. ~Ray Edited December 1, 2010 by ynkedad Quote Link to comment Share on other sites More sharing options...
Derek up North Posted December 1, 2010 Share Posted December 1, 2010 I think the siding will be fiberglass. So the easiest way to repair it would be with fiberglass. The trick will be to get an acceptable match for both the colour AND texture. Depending what's inside, you might consider through-bolting the awning back on. Quote Link to comment Share on other sites More sharing options...
acudoc Posted December 1, 2010 Share Posted December 1, 2010 Tip: click inside this box to load the editor Quote Link to comment Share on other sites More sharing options...
acudoc Posted December 1, 2010 Share Posted December 1, 2010 When my rear ladder pulled out I used aluminum diamond plate. cut it about 12x6 to spread out the stress. screwed that into the wood I put behind it then attached the ladder. I should work for the awning too. Henry Quote Link to comment Share on other sites More sharing options...
ynkedad Posted December 3, 2010 Author Share Posted December 3, 2010 Quote Link to comment Share on other sites More sharing options...
