olddude Posted September 4, 2006 Share Posted September 4, 2006 My 1990 Odyssey has a water tank under the center sofa. I don't have a drain valve on the outside of the coach, how do you drain the tank? Owners booklet says to shut off the water pump when draining the tank, so that means you don't drain thru the sink faucet into the gray tank. Where is the valve? Thanks Quote Link to comment Share on other sites More sharing options...
MC1987 Posted September 10, 2006 Share Posted September 10, 2006 Olddude - I have an 87 Mini Cruiser with an 80 gal water under the sofa, too. On the side of the take there is a valve, much like you would find on a box of wine. It ends up draining through the floor. It takes forever. Hope this helps. Quote Link to comment Share on other sites More sharing options...
