Hi everyone,
I have had my MH for a little over a year now and I think my 22RE engine (1987 Toyota Dolphin Auto) needs some serious cooling. It is because at interstate freeway speeds (I have to try keep it up at around 60-65mph range constantly, I think driving at the 50-55mph range is just not too practical on the interstate) the engine heats up pretty quickly and soon the temp guage is reaching around 3/4 towards hot and sometimes even higher. The expansion tank keeps overflowing and the next morning there's always the need to add coolant directly to the radiator (usually around 250ml). The timing kit, head gasket, fan clutch, oil pump, water pump, thermostat, radiator (3-row) all have been replaced last year or early this year, before the replacement the temp needle will reach the top of the normal operating temp range (but never cross into red). After those parts replacements the temp will reach around 3/4 of normal operating range. I would seriously appreciate some suggestion as to how to practically lower the engine temp and thus at least the coolant won't be so hot it overflows the expansion tank.
Thanks for your help.
  • Replies 82
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Hi everyone,
It sounds like you're engine is working too hard for the speed you want to drive at. Maybe your radiator needs to be removed and flushed out as well as the engine block.
John
Hi,
I drove my '84 Sunrader with a 22R and manual transmission over 1000 miles this last week up and down mountain passes, 60-65 mph on the freeway, and up to 90° heat over the last week and the temp gauge never went up over about 1/4 of the way. I suspect you have a problem that needs to be fixed. Looks like you've already addressed the most likely culprits, but something's not right!
-Brad
Hi everyone,
You have an interesting problem sounds like you have tried all the normal stuff. If it was not for the fact you seem to be losing coolant I would say your gauge is laying. There is a small band near the top red zone that is hot any thing below that is not I know that does not seem right and most are lower but it's true but still the issue with it pushing out coolant. Has any one approched the possibility of a leaking head gasket? If you are friends with a shop that does emissions checks have them scan the radiator just above the water and see if they come up with CO with the probe.
The first thing is to be sure you have the correct thermostat .
I have a v-twin motorcycle that is air cooled,in slow traffic it would run hot( I have a temp gage in the oil tank on the side of yhe bike.) I changed to a synthetic oil and the oil temperature went down.
If you change the oil yourself it will cnly cost about $8 more than a good dino oil.
LW
Many thanks for everyone's reply. Please see my response below:
John
Hi John: Thanks for the reply. I did do a flush on the cooling system when I replaced the radiator.
Hi,
-Brad
Hi Brad: Yeah, I suspect that too but don't know what it is!
Hi Maineah: Head gasket was replaced along with the timing kit, with new head bolts. Friend that owns the shop did an emission scan on top of the radiator neck shows no CO nor HC. The timing kit (chains, gears) have all been replaced along with thermostat, water pump, oil pump and fan clutch.
LW
Hi LW: My friend uses Mobil 1 5W50 for me, and he chooses the 2 stage Toyota Thermostat for me, check this for details. Part #:90916-03070.
Most of us have switched the stock radiator out for the larger three chamber. The stock radiators weren't intended to cool the 22r at constant 3,000 plus revs. Also, I would adress this asap. Those aluminum heads tend to chip when hot where the water passages don't line up perfectly with the block and headgasket. Unfortunately, I found out the hard way and ended up having to replace the cylinder head. Wish I had a pic, it looked like pitting that eventually made its way towards the combustion chamber and had me going through 02 sensors like no other.
Is the engine running too lean? Proper fuel mixture keeps the head cool(er). Spark plug gap correct? Changes timing. Is it the thermostat? 160, 180, and 192 degree thermostats are available. Fan not operating correctly?
Just sayin'
Allen
When you say expansion tank I assume you are talking about the plastic one? What is the pressure of the radiator cap? There is a small brass ring below the rubber seal on the cap the ideal with that is to allow the coolant to be returned to the radiator from the overflow tank as it cools. You may try a cap that has higher pressure rating water under pressure will absorb more BTU's and will raze the boiling point.
Just sayin'
Allen
Hi Allen: The thermostat is 180 I believe. Spark plugs were replaced too, the gap was correct. Fan clutch is new.
Please excuse me. Just saw that you mentioned already using a three row radiator.
Allen's advice seems dead on. Definitely inspect the timing.
Hi ILIA: Timing was checked after the head gasket/timing gear job.
Hi Maineah: Yes, the expansion tank is the plastic container to hold the coolant. The radiator cap was replaced along with the 3-row radiator. It says 0.9 on it. Do you have a brand/part number I can try? This seems to be a low cost thing and definitely worth a try, thanks.
Did you get this problem fixed? I am having the exact same problem on my 88. I think it may be a plugged radiator.
Thanks
No, I haven't got the problem fixed yet. I took the MH to my mechanic friend's shop and he checked the timing for me, it was ok. Also he used the coolant flush machine to do a coolant flush, and the problem remained the same. It only happened when I drive on interstate speed (60-65mph continuously) but if I drive slower then it was ok.
OK I'm guessing what you have is a .9 bar cap that would be about 13 psi. that's about right. So there really is nothing wrong with your MH it's all in your head! Have you considered yoga and meditation? ¾ scale is not really hot I some times running the A/C on a really hot day can do that but I still don’t get the coolant being forced out. Can your guy pressure check the cap? (they are small he would need an adaptor). Another thing could be too much antifreeze it should be no greater then 50% (-32F). I’m running out of ideals as I’m sure you are have you tried a new temp sensor?
OK I'm guessing what you have is a .9 bar cap that would be about 13 psi. that's about right. So there really is nothing wrong with your MH it's all in your head! Have you considered yoga and meditation? ¾ scale is not really hot I some times running the A/C on a really hot day can do that but I still don't get the coolant being forced out. Can your guy pressure check the cap? (they are small he would need an adaptor). Another thing could be too much antifreeze it should be no greater then 50% (-32F). I'm running out of ideals as I'm sure you are have you tried a new temp sensor?
Hi Maineah: I don't mind the 3/4 guage but for coolant keep pushing out from the expansion tank that's scary. Really don't want the MH to breakdown in the middle of nowhere. And I need to add coolant everyday when I took it to the highway. Antifreeze I use is 50/50 mix Water with Toyota Longlife Coolant. New temp sensor, not yet, but will try that soon.
After highway driving when I open the hood I won't actually see the coolant spilling out (I guess it spills out during driving) but the expansion tank is all full of coolant. The next day, everything cools down, there's no coolant left in the expansion tank and upon opening the radiator cap inside you always need to add about 1/4 of a liter of water/coolant to fill it to the top of the rad.
Use a point and shoot IR temp sensor gun and check the actual temp of the header tank.
Start with a full radiator and the expansion tank filled to less than the cold line and see what happens.
I had a problem once with a 1977 FJ40, I did everything i could to lower the temp, but noting worked... It turned out to be when i replace the watter pump, it worked too good for the old rubber hose that looked in top shape. I bought a complete new set and had perfect cooling. Of course it was the last thing left to replace on the cooling system...
Any luck yet? I have exactly the same problem with exactly the same rig you have, same tranny and engine.
How irritating to not be able to go over sixty with peace of mind, huh. Please let me know what you find. I'm going to start from the very beginning with replacing the small stuff. Thanks. Victor
You can email me at vgonzalez4630@yahoo.com appreciating any info.
Will do that next time I have a chance to bring it into my friend's shop. The thing is, if I just let it idle the coolant temp will only stay at 1/3 of guage and won't go up. Coolant won't be rushing out from the expansion tank either.
Water pump was replaced in my MH along with all rad hoses when doing the timing gear kit/head gasket replacement, Yes, now it won't reach the top of the normal operating range (white zone) on the guage but still up to 2/3 and coolant rushing out at highway speeds.
I believe in the end there are many things that contributed to this problem. At some point you'll either have to move to some more expensive item or try to live with it. I rely my MH not on everyday basis but when I am on holiday with my family. Although it has this problem it did take me from Vancouver, BC all the way down the Los Angeles last Christmas and back. And I went to the Cascade Loop in Washington (5477 ft elevation) just a couple of weeks ago. My mechanic told me that it's not something really major at this moment but keep monitoring it so it won't get worse. So if nothing happens after the coolant sensor changes then I would most likely call it quits for the time being.
OK that's good the tank is doing what it should do, next time put the 1/4 liter in the the plastic tank instead of he radiator and see if it equals out next time you drive it. What it maybe is over full of course it all expands when it gets hot and has to have some place to go and the tank is it.
I did try that before. What happened was after highway driving the next morning same thing happened and the coolant is sitting a bit lower from the top of the radiator, nothing in the expansion tank, and I have to put roughly the same amount into the radiator to make it goes to the top.
22re are famous for forming an air bubble in the head and it can be a real pain to clear it out. 2 simple tricks.
Keep adding water to the over flow and never to the radiator. A 1/8" hole in the thermostat flange will let the air bleed out over a few days. Also jacking up the front end when the engine is hot has help some get the bubble out of the head.
In truth I cant see the bubble lasting this long, but it sure caused me grief for a while last time I replaced the antifreeze.
Many thanks for the reply and suggestion. That's why few days ago I went to my mechanic friend's shop and he did a coolant flush for me. He used a Vacuum system to suck all the coolant out and replaced with new coolant. So I think in my case shouldn't be any air bubble forming in the cylinder head.
oh goodness! I just took my MH out for the first long trip and had the same exact problems as you guys. When going 60-65 mph the temp gauge sky rockets. It goes up to right before it hits red, this is usually the time i would stop and let the engine cool down. After cooling the rad would be really low and I would have to add water. I'm not liking having to drive 50 mph on 65-75 mph roads :(. Keep us updated if anyone finds a fix. I was thinking of changing the temp gauge soon.
What about your distributor? Has that been checked. Bearings can wear, advance mechanism can wear. If it does not advance correctly the timing will be incorrect at the higher RPM's. Just a though. What about the computer having a brain fart. Disconnect the battery and reset it.
Yes, it's quite annoying. If you find a fix don't forget to mention here!
Last owner of the MH replaced the Distributor, Cap & Rotor in 2008, so I think this scenario is highly unlikely.
I am with the Air Bubble in the head folks but I have a trick for ya
take a 1litter pop bottle
chop off the bottom
tape bottle to the radiator filler neck.
fill with coolent to top of the bottle.
start truck and let warm up
bubbles with start to bubble out of the radiator
let cool then take off bottle spilling coolant all over
if you do this right it should run cool
this is a trick I used on the trickey 2tc hemi head bubles hide in those all the time
hope this helps
Ken
I hope this helps
PS if you dont have the fan shroud and air dam in place get them I was impressed with the diffarnence
Edited by kayakken
oh goodness! I just took my MH out for the first long trip and had the same exact problems as you guys. When going 60-65 mph the temp gauge sky rockets. It goes up to right before it hits red, this is usually the time i would stop and let the engine cool down. After cooling the rad would be really low and I would have to add water. I'm not liking having to drive 50 mph on 65-75 mph roads sad.gif. Keep us updated if anyone finds a fix. I was thinking of changing the temp gauge soon.
I have the exact same problem and was told by a mechanic that these vehicules frequently leak from the head, and that the gases escaping from the combustion cause the thermostat to malfunction. Either way, what he recomended was take it to an emmissions place and have them check the radiator fluid while the care is hot and running to see if there are exhaust gases in it. Heating a high speed then would be a sure sign of leaking head gasket. I'm gonna try it
Might as well add 2 cents worth we had heating problems with some new Equipment only in 100 deg weather They used something called water wetter and cut down on the Anti freeze ratio for the Summer. In a different unit with a heating problem or so we thought after a lot of work and wasted time it turned out to be the fill neck on the radiator the ramps where the cap turns down as the cap is tightened were worn so the 10 psi cap wasn't down far enough to hold the correct pressure spitting out water when running like a head gasket, was a bad call, replaced the fill neck problem solved.
chop off the bottom
hope this helps
Ken
I hope this helps
Yes, I know what you are talking about in fact my mechanic friend has one yellow rad funnel kit and does the exact same thing we did that in the first place and don't seemed to be it. The fan shroud is in place I don't know what you mean by air dam.
I think it's getting likelier that there's a leak not from the head gasket because I have had that replaced before along with new head bolts but my mechanic friend told me the combustion chamber looks cleaner than usual so maybe there's a leak from either the cylinder head or the engine block.
Here is another idea, too much anti freeze?
I use Toyota Long life coolant 50/50 mix. Both rad cap and radiator was replaced earlier this year, and this happens even before the radiator replacement.
UPDATE: No change after coolant temp replacement today. Checked timing again today - it's right on.
Edited by centralman
Back to WAGs. Is the radiator sealed against the radiator core support?? There should be a strip of foam rubber between the radiator and the support. The idea is so ALL the air coming through the grill is forced through the radiator. If its missing you can bypass a lot of air around the radiator
If its missing use some home A/C wrap around foam and see what happens.
Thanks for the suggestion the support (I suppose the metal frame that mounts to the radiator) is not sealed. I'll try to seal it with something and test it on the next available opportunity.
