Sign in to follow this
desertrat
Speaking of flashers
On occasion, my left flasher will sound very fast as I'm signaling. The next time I use it, it will sound with a normal slow clicking noise. I can visualize that the lights/flasher are working when it sounds slow and normal. Haven't visualized it when it has made the fast clicking sound. I'm sure it's probably a bad flasher unit, but I wondered if they should either work or fail, not intermitantly work. Any ideas?
Thanks in advance
Thanks in advance
Usually if they click fast you probably have a bulb that is not working. Bad ground maybe or dirty bulb contact hit or miss.
As always, Thanks Maineah. When I get home, I'll check out the contacts and ground.
