desertrat Posted February 5, 2010 Share Posted February 5, 2010 On occasion, my left flasher will sound very fast as I'm signaling. The next time I use it, it will sound with a normal slow clicking noise. I can visualize that the lights/flasher are working when it sounds slow and normal. Haven't visualized it when it has made the fast clicking sound. I'm sure it's probably a bad flasher unit, but I wondered if they should either work or fail, not intermitantly work. Any ideas? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Maineah Posted February 5, 2010 Share Posted February 5, 2010 On occasion, my left flasher will sound very fast as I'm signaling. The next time I use it, it will sound with a normal slow clicking noise. I can visualize that the lights/flasher are working when it sounds slow and normal. Haven't visualized it when it has made the fast clicking sound. I'm sure it's probably a bad flasher unit, but I wondered if they should either work or fail, not intermitantly work. Any ideas? Thanks in advance Usually if they click fast you probably have a bulb that is not working. Bad ground maybe or dirty bulb contact hit or miss. Quote Link to comment Share on other sites More sharing options...
desertrat Posted February 5, 2010 Author Share Posted February 5, 2010 Usually if they click fast you probably have a bulb that is not working. Bad ground maybe or dirty bulb contact hit or miss. As always, Thanks Maineah. When I get home, I'll check out the contacts and ground. Quote Link to comment Share on other sites More sharing options...
