Rear Axle's
I just bought a Sunrader 87 turbo 4x4, and it has the non-floating axle. What I wanted to know has anybody ever gone to a Dana 60, or Ford 9" or a Chevy 12 bolt floating type axle? What I would like to do, is find one of these axles, and go to one tire, instead of duallies. I think there would be a slight decrease in friction, since there would only be 2 rear tires on the pavement, which would mean a power increase. I would have to use a load range "E" tires, and I would have to find a wheel with the correct off-set. What have you guys used for wheels, when you go to the Toyota full floating 1 ton axle, since as far as I know, they only came with 14" wheels? Also, would like to go to LT30x9.50x15" tire, and get rid of the whimpy P215x75x15". This motorhome came with 5:13 gears, what is the normal gear ratio? Thanks, Dave, high in the Colorado Mtns.
You might look into a narrowing a 10.5" ring gear GM 14 bolt axle (ton)
http://www.chuckschevytruckpages.com/14bolt.html
http://www.pirate4x4.com/tech/billavista/1...ible/index.html
Dirk, thank you, that was extrememly helpful, I didn"t know you couldn't get a 12 bolt, in a full floating design, this is the rear end I'll be looking for. Again, thanks!
Dave Campa
