CorunnaCamper Posted April 6, 2009 Share Posted April 6, 2009 I recentally bought a 1990 6-cylander automatic Itasca. I was getting it checked out and the mechanic said i should replace my Timing Belt(109,000 miles).I was wondering if it was nececicary if i should replace it or if he was trying to sell me something that i don't need? Quote Link to comment Share on other sites More sharing options...
Maineah Posted April 6, 2009 Share Posted April 6, 2009 It,s due replace it. Quote Link to comment Share on other sites More sharing options...
bufbooth Posted April 7, 2009 Share Posted April 7, 2009 The timing belt should be replaced at 80,000 miles. If it breaks, you could be looking at needing a new engine. You could get lucky and the engine just dies, or unlucky and a few Pistons bump into a few values, which besides piston and valve damage you could have head and cylinder damage, making the engine pretty much a complete lost. Dennis... Quote Link to comment Share on other sites More sharing options...
fire362 Posted August 30, 2009 Share Posted August 30, 2009 Hi guys, Couldn't find the link where to buy the medal timing chain guides. I gotta get on replacing also. Thanks Ken 1986 Sunrader 4x4 The timing belt should be replaced at 80,000 miles. If it breaks, you could be looking at needing a new engine. You could get lucky and the engine just dies, or unlucky and a few Pistons bump into a few values, which besides piston and valve damage you could have head and cylinder damage, making the engine pretty much a complete lost. Dennis... Quote Link to comment Share on other sites More sharing options...
jim Posted August 31, 2009 Share Posted August 31, 2009 Hi guys, Couldn't find the link where to buy the medal timing chain guides. I gotta get on replacing also. Thanks Ken 1986 Sunrader 4x4 Just a reply about timing belt breaking on a 3vz toyota, they are not an interference engine, meaning belt can break and there will be no contact between pistons and valves, however best to replace as even though engine damage will not result the cost of tow and inconvenience if away from home will be considerable. By the way I am a Toyota master technician and over the last 20 years have seen dozens of these belts break and damage will not happen. Only the newest toyota timing belt equipped engines ie tundra 4.7 v8 are interference engines. Jim Quote Link to comment Share on other sites More sharing options...
kuzbro Posted October 25, 2009 Share Posted October 25, 2009 Jim, Thanks for the information. My timing belt is up for replacement in about 5000 miles. Did Toyota ever upgrade to a stronegr belt that suppose to last longer? And, is there a special tool need to get the job done? Quote Link to comment Share on other sites More sharing options...
jim Posted October 25, 2009 Share Posted October 25, 2009 Jim, Thanks for the information. My timing belt is up for replacement in about 5000 miles. Did Toyota ever upgrade to a stronegr belt that suppose to last longer? And, is there a special tool need to get the job done? No there is no stronger belt, they just have to be changed at the proper intervals, I have seen people go farther than recommended but I have also seen them break before time to replace. Here in Canada where I am the interval in 96000 kilometers which is about 60000 miles. You do not need special tools except maybe if harmonic balancer (on front of crankshaft) is hard to get off, you may need a puller, but you need to be fairly mechanical to do this job, remove radiator, harmonic balancer, front covers and fan support, then need to get the new belt on and timed properly. Get a repair manual or download instructions . Also if engine is high mileage or hasnt had best of oil change maintenance is a good time to replace crankshaft and camshaft seals and have a good look at water pump and timing belt idler and tensioners. Once again the 3vz engine is not an interference engine so piston to valve damage will not happen if belt does break, however it is cheaper and less stressfull to get it done at home and not in the middle of a trip! hope this helps Jim Quote Link to comment Share on other sites More sharing options...
sharon333 Posted October 28, 2009 Share Posted October 28, 2009 Thanks for the help. My father has been looking all over for this timing belt info. Quote Link to comment Share on other sites More sharing options...
