Where is the fuse box for appliances on a huntsman?
Hi! I have a 1983 huntsman. Months ago a rat chewed through a water line right above wires, which it chewed the casings off of, and the water getting onto the wires caused the heater and the fridge to stop working. Uhg! So I'm trying to figure out how to fix this. My best advice so far is to find the fuses and replace them and rewrap the wires. But where are the fuses?
Also, If you have any other suggestions..?
Thank you!
Check where your your shore power cord goes into the camper. The fuse box should be inside near where the power cord goes through the wall. It should have a plastic or tin cover.
Hole is on the outside. Fuse panel should be on the inside opposite of it. Look for vented metal door near floor or take pics of the inside near floor from multiple angles. Well find it
Many older ones had the DC fuse panel inside of the converter charger behind a small door.
