MaineJed Posted July 5, 2020 Share Posted July 5, 2020 Started repairing leaks today and the interior walls as a result of the leaks. The Luan is glued to styrofoam insulation that is glued to the backside of the fiberglass exterior. Can anyone point me in the right direction to get the luan and styrofoam out in a quicker way. Attached is a pic, look at the small section under the window for explanation. Thanks all. Quote Link to comment Share on other sites More sharing options...
lansisco Posted July 6, 2020 Share Posted July 6, 2020 19 hours ago, MaineJed said: Started repairing leaks today and the interior walls as a result of the leaks. The Luan is glued to styrofoam insulation that is glued to the backside of the fiberglass exterior. Can anyone point me in the right direction to get the luan and styrofoam out in a quicker way. Attached is a pic, look at the small section under the window for explanation. Thanks all. I had a similar situation, I gutted everything and started from scratch. Quote Link to comment Share on other sites More sharing options...
MaineJed Posted July 6, 2020 Author Share Posted July 6, 2020 That’s the way that I’m going. What is everyone using for small holes in the siding? I have Lap seal, anything better to use? Quote Link to comment Share on other sites More sharing options...
linda s Posted July 6, 2020 Share Posted July 6, 2020 I think something stronger is in order. I would go with bondo or fiberglass repair kit. Something sandable to give you a smooth strong result Linda S Quote Link to comment Share on other sites More sharing options...
