I found water pump in my rigg leaking at the joints. Water seeps out only when the pump is running. Could this be fixed ??
If not, Could some one help me find the right water pump please. I want to make sure I have the right equipment.
Attached photo is of the one I removed from under the sofa bed. It is a Shurflo model number 2088-403-144 , 2.8 GPM
I found one at ebay with different model number but has 3.0 GPM flow:
https://www.ebay.com/itm/New-Shurflo-4008-101-E65-RV-Camper-Marine-12V-Fresh-Water-Pump-3-0-GPM/392432911544?epid=658421542&hash=item5b5ed304b8:g:BrQAAOSwe2JdglQb
I will appreciate your help.
Thank you.
Pretty much if you have seen one you have seen them all the fittings etc are the same you really do not need a higher demand pump but it won't hurt anything.
2.8GPM vs 3.0GPM won't do any harm. These are just the maximum flow rates. IF (and I doubt you will) find a new pump flows too much water, just adjust the tap.
