kevinchinook Posted June 28, 2020 Share Posted June 28, 2020 I have a 1986 toyota sunrader adventure(pop-top). I really want to put a fantastic ceiling fan but given the large fiberglass pop-top I have no idea where the internal supports/beams are. Anyone have decent ideas on how to make the hole as painless as possible? I was going to try to use a studfinder but unsure if that would work. Quote Link to comment Share on other sites More sharing options...
linda s Posted June 28, 2020 Share Posted June 28, 2020 I'm trying to understand why. Are you trying to get more ventilation when the top is down? When it's up and the windows on the canvas are open there's a natural chimney effect that draws air in through the windows. If you want more movement a 12 volt fan like this can be clipped up top or even clipped on so it's blowing right at you. No damage and extremely cheap. https://www.walmart.com/ip/12V-DC-Car-Electric-Oscillating-Fan-Portable-Cooler-Clip-For-Vehicle-Van-Trunk/355207373 If you really want a hole in your roof a fantastic fan only weighs about 12 lbs. Supports not needed. Just in case there are any metal supports in there you want to avoid them. Use a stud finder Linda S Quote Link to comment Share on other sites More sharing options...
Maineah Posted June 28, 2020 Share Posted June 28, 2020 Does it have a vent in the roof? If it does then a fantastic fan can be used in its place. Quote Link to comment Share on other sites More sharing options...
