Sign in to follow this
Hunter.
Drain Hot Water Heater Tank
Does anyone know if I drain the fresh water tank, does it also drain the Hot Water tank? Or if there is a separate drain valve on the HWH tank? Or any suggestions? 1985 Toyota Dolphin.
Thanks, Hunter
No that won't drain your hot water tank. There should be a drain plug on the outside. If you can tell us what hot water heater you have we should be able to show where it is or google it. Lots of manuals for older appliances online
