hamkid Posted January 5, 2020 Share Posted January 5, 2020 I installed a new transmission pan gasket and did not take note of the bolts as I removed them. I have 8 bolts with a star on them, 3 bolts with the number 9 on them and 3 bolts with the number 4. Is there a certain scheme these bolts go in? Quote Link to comment Share on other sites More sharing options...
WME Posted January 5, 2020 Share Posted January 5, 2020 Somebody has been mucking about on your transmission. The bolts with a 6 point star are SAE (American) the one with numbers are metric. A 1/4x20 bolt will fit in a 6x1.25 hole, not very well but it can be done. Look carefully at the bolts with the numbers on the head. Metric will be marked like 4.8 or 8.8. You need to see what metric bolt is needed and get a metric tap and clean out the threads and use new hardware. Quote Link to comment Share on other sites More sharing options...
hamkid Posted January 5, 2020 Author Share Posted January 5, 2020 Is it a problem that I used gasket sealer on both sides of the gasket? Quote Link to comment Share on other sites More sharing options...
WME Posted January 5, 2020 Share Posted January 5, 2020 3 hours ago, hamkid said: Is it a problem that I used gasket sealer on both sides of the gasket? Not at this instance, but next time the pan comes off you are going to be doing a lot of scraping laying on your back. What gasket sealer did you use?? Simple answer is a thin film of sealer on the pan and a thin film of grease on the transmission. That way the gasket comes of the transmission with out scraping and you can clean the pan on the work bench. Quote Link to comment Share on other sites More sharing options...
hamkid Posted January 5, 2020 Author Share Posted January 5, 2020 Versachem brand gasket sealant type 1 Quote Link to comment Share on other sites More sharing options...
WME Posted January 5, 2020 Share Posted January 5, 2020 stop leaks, yes. Easy scrape no Quote Link to comment Share on other sites More sharing options...
hamkid Posted January 5, 2020 Author Share Posted January 5, 2020 Toyota dealership doesn’t supply the bolts I need, where else should I try next? Quote Link to comment Share on other sites More sharing options...
linda s Posted January 5, 2020 Share Posted January 5, 2020 Try here https://www.toyotapartsdeal.com/oem/toyota~bolt~for~automatic~transmission~oil~pan~90119-06117.html?Make=Toyota&Model=Pickup&Year=1985&Submodel=&Filter=(d=USA;3=T1;7=RCB;9=HVY;13=IV)&Location=transmission-case-oil-pan-atm,, Linda S New part number has been changed to this 90080-11496 Bizarre that they said they couldn't get it for you. Same bolt is used on dozens of Toyota vehicles all the way up to 2016 Quote Link to comment Share on other sites More sharing options...
WME Posted January 5, 2020 Share Posted January 5, 2020 Just looking at them are they all about the same size?? Take a metric one to your local NAPA store and see what they have. The problem going to be the holes that had SAE bolts in them, is there enough thread left to go back to metric bolts. Worst case you may end up using an SAE tap and making all the bolts holes SAE. These are just simple bolts you don't need grade 8. Quote Link to comment Share on other sites More sharing options...
hamkid Posted January 9, 2020 Author Share Posted January 9, 2020 I ordered and installed the new bolts that Linda recommended. They seemed to install and tighten properly. It seems the threads are not damaged. Thanks for all the help! Quote Link to comment Share on other sites More sharing options...
Maineah Posted January 10, 2020 Share Posted January 10, 2020 On 1/4/2020 at 8:14 PM, hamkid said: I installed a new transmission pan gasket and did not take note of the bolts as I removed them. I have 8 bolts with a star on them, 3 bolts with the number 9 on them and 3 bolts with the number 4. Is there a certain scheme these bolts go in? Sounds like someone has been there before. Have you all ready put it back together? It kind of sounds like you have some US standard bolts mixed in with metric. With the age they probably broke some bolts and repaired them with 1/4 20 bolts. Quote Link to comment Share on other sites More sharing options...
