Odyssey 4x4 Posted February 5, 2020 Share Posted February 5, 2020 39 minutes ago, hamkid said: These are the mechanical issues that can cause a person to go insane! Quote Link to comment Share on other sites More sharing options...
hamkid Posted February 5, 2020 Author Share Posted February 5, 2020 I wouldn’t quite say insane yet, just one step closer! 🤪🤬 Quote Link to comment Share on other sites More sharing options...
Maineah Posted February 6, 2020 Share Posted February 6, 2020 (edited) That actually looks like a good joint if moving it around changes things then yes it is suspect. That looks factory can you follow it further? I can't make the photos work and explanation work again I'll try later. Edited February 6, 2020 by Maineah Quote Link to comment Share on other sites More sharing options...
hamkid Posted February 6, 2020 Author Share Posted February 6, 2020 Pretty sure that was the problem. Charge light on dash turned off. Charge circuit fuse shows power. Battery charges. When the lights and cab heater are on it does not charge as well. Should I clean the splice or consider making a new one? Quote Link to comment Share on other sites More sharing options...
Maineah Posted February 6, 2020 Share Posted February 6, 2020 Make a new one I don't think you will get it apart without damaging the wire ends. Quote Link to comment Share on other sites More sharing options...
hamkid Posted February 8, 2020 Author Share Posted February 8, 2020 (edited) When checking the wiring found this at the wiper fluid reservoir. Would this have an impact on the circuit? Edited February 8, 2020 by hamkid Quote Link to comment Share on other sites More sharing options...
Homer Posted February 8, 2020 Share Posted February 8, 2020 (edited) Check the end of the wire hanging down under the washer motor. See if it has been shorted out, Burned etc. If so you might can cut it off close to the end and replace. The motor may be shot also. Good Luck. Edited February 8, 2020 by Homer Quote Link to comment Share on other sites More sharing options...
Maineah Posted February 9, 2020 Share Posted February 9, 2020 No. It does need attention though. Quote Link to comment Share on other sites More sharing options...
hamkid Posted February 18, 2020 Author Share Posted February 18, 2020 One of the head light spade connectors needs to be replaced from corrosion. Any idea where I can find the same one or should I just buy an aftermarket? Quote Link to comment Share on other sites More sharing options...
Maineah Posted February 19, 2020 Share Posted February 19, 2020 Auto parts store they will have a plug with pigtails you'll have to splice them in. Quote Link to comment Share on other sites More sharing options...
hamkid Posted March 3, 2020 Author Share Posted March 3, 2020 Ok. Everything is working. Except now the coach lights don’t work. I haven’t check anything else in the coach but the lights were working before all this. Any idea what I should check? Quote Link to comment Share on other sites More sharing options...
Maineah Posted March 3, 2020 Share Posted March 3, 2020 No relation to the alt. They are fused somewhere near your converter depending on the converter the fuses may even be inside of it. Quote Link to comment Share on other sites More sharing options...
hamkid Posted March 4, 2020 Author Share Posted March 4, 2020 Ok will do. There is a squeal coming from the engine when I accelerate. How can I be sure my belts have the correct tension? Quote Link to comment Share on other sites More sharing options...
Maineah Posted March 4, 2020 Share Posted March 4, 2020 Because the alt is over driven (turns faster than the engine) the belts need to be bow string tight with very little deflection 1/4-1/2" in the center or they will squeal. Quote Link to comment Share on other sites More sharing options...
hamkid Posted March 10, 2020 Author Share Posted March 10, 2020 (edited) Tightened stopped squealing. Thanks. The headlights not working rite on passenger side. Much more dim than driver side and no high beam. Any ideas? Edited March 10, 2020 by hamkid Quote Link to comment Share on other sites More sharing options...
Maineah Posted March 11, 2020 Share Posted March 11, 2020 You sure the wires are connected properly? Copy the colors and possion from the other lamp. Quote Link to comment Share on other sites More sharing options...
hamkid Posted March 13, 2020 Author Share Posted March 13, 2020 So both sides each have a yellow and green wire, but one side has a white wire and the other has a black wire. When I crimped the new spade connector on I did not use the correct crimp tool. I ordered the one I need and will see what happens once I have a better crimp. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 13, 2020 Share Posted March 13, 2020 Autozone website has wiring diagrams that show what the wire colours should be. A good starting point. Quote Link to comment Share on other sites More sharing options...
hamkid Posted March 14, 2020 Author Share Posted March 14, 2020 Top notch mate. Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
