gabe_1994rig Posted December 12, 2019 Share Posted December 12, 2019 So my fresh water tank is full and my pump doesnt turn on so I think its done. I need to drain my fresh water tank and cant find anywhere to drain it. I have a 1994 winnabego toyota fyi. Can someone please direct me to some information on how to... or should I just drill a hole and let it drain and plug it up. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted December 12, 2019 Share Posted December 12, 2019 321RB.pdf 321RL.pdf Quote Link to comment Share on other sites More sharing options...
gabe_1994rig Posted December 12, 2019 Author Share Posted December 12, 2019 thank you SOOOOOOOOOOOOOOOOOOOOOOOOOOO MUCH! Quote Link to comment Share on other sites More sharing options...
Sandune24 Posted December 13, 2019 Share Posted December 13, 2019 (edited) Hi, everyone and Happy Holidays😊 Okay, I was following the diagrams that Derek posted regarding fresh water tank lines. I am attempting to winterize my 1987 Escaper. I went to the water heater first, only to find that the drain had no cover, just the opening . So I gather that my water heater is drained. Next ,I went to the rear kitchen sink, bathroom and by water pump to see if I could turn off the valve to water . Of course I can’t identify a hot or cold turn off valve...? I found that poop drain, and on each side there are to push pull knobs, that do what? I could not find the fresh water tank drain plug...? I turned the Toy on after pouring 2 gallons of RV antifreeze in the water tank fill outlet and then turned on the water pump ? Nothing from any of the faucets . Obviously missing the proper connections. I’ve watched Utube videos and nothing is the same in my Toyota Escaper that matches the procedures taken !!!?.?? Frustrated and confused as I have the Manuel’s also. HELP PLEASE 🙏 Edited December 28, 2019 by Sandune24 Quote Link to comment Share on other sites More sharing options...
Sandune24 Posted December 28, 2019 Share Posted December 28, 2019 This is the hot water heater, I previously drained or shall I say has been draining itself as there is no plug. I ordered Camco heater valves and they are way big. So I’m still in the market for drain plug . Any ideas? Thank you Quote Link to comment Share on other sites More sharing options...
Maineah Posted December 28, 2019 Share Posted December 28, 2019 Sure looks to me that the plug is in place. It has a square slot that will except a 1/2" or maybe 3/8" extension. If you are talking about the pipe with the hex fitting that is the propane feed pipe. When you replace the plug buy a plastic one you run a far better chance of getting it out again I believe it's 3/4" a standard pipe size. Quote Link to comment Share on other sites More sharing options...
linda s Posted December 28, 2019 Share Posted December 28, 2019 Compare the threads on the drain plug to the Camco part you bought. I think the Atwood plugs are supposed to be 1/2 inch but that one does look a little bigger. Is there a model number anywhere. Might help to find out exactly what you need. Linda S Quote Link to comment Share on other sites More sharing options...
