WME Posted November 20, 2019 Share Posted November 20, 2019 Well as I was wandering through my local Walmart I saw that they have a 100w solar kit. Its a folding panel, 25ft connection cable, a controller and a 400w inverter 110 ac + usb. They were also selling a 56AH LiFe battery. Price was so so. I went to the Walmart web site and they are competing with Amazon and Ebay. They were selling Renogy and Windy nation products. The prices seem to be competive. So if your in the solar market give Walmart a look. Most had free store dilivery. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 20, 2019 Share Posted November 20, 2019 2 hours ago, WME said: ... a folding panel, 25ft connection cable, a controller and a 400w inverter 110 ac + usb. Don't see that package online. How much in-store? Quote Link to comment Share on other sites More sharing options...
WME Posted November 20, 2019 Author Share Posted November 20, 2019 Panel kit...https://www.walmart.com/ip/LE-SOLAR-POWER-KIT/434096048 Battery...https://www.walmart.com/ip/LE-UT700-BATTERY/619303783 Here is a 100w Windy Nation panel...https://www.walmart.com/ip/WindyNation-100-Watt-100W-Solar-Panel-for-12V-RV-Boat-Off-Grid/923789303 Quote Link to comment Share on other sites More sharing options...
Maineah Posted November 21, 2019 Share Posted November 21, 2019 (edited) My ground mount portable panel both ends of the camper have 50 amp power pole connections, the panel can be elevated to the sun angle and of course turned into the sun for max solar gain, panel shadows are good aiming devices you don't want any except directly behind. Because I use this for numerous things the charge controller is built into the panel. It folds flat and in transport it lives on the bed. With two 80 amp batteries and the panel I can go indefinitely with all the power I really need. It was charging a 18 amp gel cell for my radios it had a untimely death at about age 12 so when I'm not using it with the camper it charges a 80 amp deep cycle for radio use. I'll put it's weight in the 15-20 lb range never actually weighted it. The 50 amp connecters are way over the top but that's what I had at the time same with the #10 SJ cord Edited November 21, 2019 by Maineah Quote Link to comment Share on other sites More sharing options...
