swany Posted October 24, 2019 Share Posted October 24, 2019 My 86 Toyota Escaper roof vibrates from 30 to 45 mph. Anyone have this problem or can offer a suggestion? Quote Link to comment Share on other sites More sharing options...
86Dolphino Posted October 24, 2019 Share Posted October 24, 2019 I'm not sure if this is your problem but I remember when I got my 86 Dolphin I had a weird vibration at about 50 (quite bad too) and my problem was dirt dried up around the inner rear rims. putting them out of balance. Once I cleaned all the mud/dirt out of the rims they road smooth. may want to check that see if its your problem. Quote Link to comment Share on other sites More sharing options...
RS Hinks Posted November 3, 2019 Share Posted November 3, 2019 I don't know if you got an answer to your roof vibration question. Without hearing/seeing it it's difficult to say for certain, however it could be caused by having a loose roof, that is, for example, if your roof is aluminum, and is not adhered by glue or screws to the load bearing structure in your roof then it will likely vibrate as you hit higher speeds and it goes through a vibration resonance. Quote Link to comment Share on other sites More sharing options...
