bobbo138 Posted August 17, 2019 Share Posted August 17, 2019 Have a question about re-arching the roof on my 87 Sunrader. I have a sagging roof that I need to raise. I jacked the roof up under the AC area until it started creaking, at which point it looked like it more or less matched the arch at the front and rear of the roof. However when viewed from the exterior there is still dip at the edge of the roof line. My question, having never seen an original roof, is whether that dip is supposed to be there or whether I need to jack further. I have attached some pictures to help clarify what I mean by the dip. Thanks for any and all help. Quote Link to comment Share on other sites More sharing options...
linda s Posted August 17, 2019 Share Posted August 17, 2019 There is only so much you can do to bend fiberglass. That dip is so close to the edge and so even all around it will have almost no flexibility. Seal everything else well and park on slight incline if you can. If it still seems to pool throw a long piece of cheesecloth up there with side hanging down. It will wick water away. I'll look at mine when I get home and post is I have same edge Linda S Quote Link to comment Share on other sites More sharing options...
bobbo138 Posted August 18, 2019 Author Share Posted August 18, 2019 Linda, thanks for the reply. I was afraid that might be the case. At the moment I’ve got the ceiling jacked in the center of the ceiling using a roughly 2’x2’ piece of plywood to spread the load. I’ll try swapping it for a piece closer to the full width of the ceiling and see if I can’t get the edges up a bit more. Quote Link to comment Share on other sites More sharing options...
WME Posted August 18, 2019 Share Posted August 18, 2019 Take a 2x4 on edge and put a 1" curve in top . Make it the full width of your house. Sunrader put some ribs in their later models to support the roof A/C. Quote Link to comment Share on other sites More sharing options...
bobbo138 Posted August 19, 2019 Author Share Posted August 19, 2019 WME, when you say a 1” curve do you mean a 1” drop from the center to the edge? As in trace out an arc that starts at the center of the 2x4 and drops 1” to each side? Quote Link to comment Share on other sites More sharing options...
WME Posted August 19, 2019 Share Posted August 19, 2019 Yes a 1" drop from center. Make it a continuous curve. If you like the results then use the same curve on the bottom and make a 2" beam. Make one for each side of the A/C. Quote Link to comment Share on other sites More sharing options...
AmyDC Posted August 19, 2019 Share Posted August 19, 2019 Hi Bobbo! I was up on the roof of my Sunrader over the weekend and for what its worth - I also have that dip next to the roof edges as well. I'll be starting the demo phase inside soon and I plan on adding interior roof supports then as there ain't much now. I'll keep ya posted. Quote Link to comment Share on other sites More sharing options...
cannante Posted November 29, 2019 Share Posted November 29, 2019 I am going to put in I am going to put in 3 by 4 beams and the two by four with the one-inch curve as per the above suggestion as soon as I fix the leaks. The week's is this week's project before it rains and snows here! Quote Link to comment Share on other sites More sharing options...
JaySam Posted January 3, 2020 Share Posted January 3, 2020 Did you ever add in supports for your roof? I also have a sagging Sunrader roof and would love to see some pics or a description of how you addressed the issue. Quote Link to comment Share on other sites More sharing options...
Otolith Posted February 26, 2020 Share Posted February 26, 2020 Can anyone post a photo of the sunrader roof that is not sagging at all? Is it totally flat? Or curved upwards? Quote Link to comment Share on other sites More sharing options...
86rader Posted March 21, 2020 Share Posted March 21, 2020 Every single Sunrader roof I have ever seen has a slight concavity to it. Why the hell they didn't do the opposite escapes me. As for putting large beams inside to hold it up, like 3x4s?, yeah, I 'spose you could, but SRs are kinda lacking in headroom already. Quote Link to comment Share on other sites More sharing options...
linda s Posted March 21, 2020 Share Posted March 21, 2020 3x4's are only needed when adding a second story Linda S Quote Link to comment Share on other sites More sharing options...
