BBC3 Posted July 16, 2019 Share Posted July 16, 2019 Hi there, My water smells of sulphur. I've read up a bit and plan to put Hydrogen peroxide in the fresh water tank, and hot water tank and let it sit for a bit and then flush it. I do not drink the water from the RV, and use bottled water. But I do shower in it. Do I need to use a water purification tablet or something like that in the fresh water tank once i have flushed it with the peroxide? As always, any advice, or guidance much appreciated. Cheers! Quote Link to comment Share on other sites More sharing options...
WME Posted July 16, 2019 Share Posted July 16, 2019 Yah skunk water😝. Prevent by draining your system, including the water heater in the winter and a few times in the summer. I use this with a 3x dose for the first time in the spring and a standard dose with each fill up. https://www.walmart.com/ip/Camco-TastePURE-Drinking-Water-Freshener-Prevents-Algae-and-Slime-Build-Up-in-Your-Drinking-Water-Tank-Rids-Odors-and-Bad-Tastes-16-oz-40206/14504326?wmlspartner=wlpa&selectedSellerId=1148&adid=22222222227008504182&wl0=&wl1=g&wl2=c&wl3=40839114032&wl4=pla-78652545272&wl5=9029305&wl6=&wl7=&wl8=&wl9=pla&wl10=112562587&wl11=online&wl12=14504326&veh=sem&gclid=EAIaIQobChMI2sTTnIa64wIViR-tBh1rQgXwEAQYBSABEgJfjvD_BwE Quote Link to comment Share on other sites More sharing options...
BBC3 Posted July 17, 2019 Author Share Posted July 17, 2019 6 hours ago, WME said: Yah skunk water😝. Prevent by draining your system, including the water heater in the winter and a few times in the summer. I use this with a 3x dose for the first time in the spring and a standard dose with each fill up. https://www.walmart.com/ip/Camco-TastePURE-Drinking-Water-Freshener-Prevents-Algae-and-Slime-Build-Up-in-Your-Drinking-Water-Tank-Rids-Odors-and-Bad-Tastes-16-oz-40206/14504326?wmlspartner=wlpa&selectedSellerId=1148&adid=22222222227008504182&wl0=&wl1=g&wl2=c&wl3=40839114032&wl4=pla-78652545272&wl5=9029305&wl6=&wl7=&wl8=&wl9=pla&wl10=112562587&wl11=online&wl12=14504326&veh=sem&gclid=EAIaIQobChMI2sTTnIa64wIViR-tBh1rQgXwEAQYBSABEgJfjvD_BwE Thank you. Quote Link to comment Share on other sites More sharing options...
