Porch Light - Bargman Lighted assist bar
Hi All, so I've found a couple threads about replacing different parts of the lighting assembly that's next to the door to the coach on our 1987 Dolphin.
I've got a new lens cover and switch ordered because it was rusted out, but what I can't figure out is where to buy a replacement light socket that will fit into the assembly.
Is this just a general sized light socket of some kind??
Any help would be much appreciated...
3 minutes ago, Derek up North said:
I think a trip down to your local parts store will get you a bulb socket. It even doesn't have to be for the same bulb as the original. Pick up a matching LED bulb while there. Some fabrication might be needed to install.
Great, thanks Derek. That's what I'll do!
  • 4 weeks later...
Can you tell me/us where you got the switch? I’m at the same point of repair! Also, did you figure out the bulb issue? Thanks!
Hi Caribemj,
Mine actually had a toggle switch rather than that pop style that you have, and I found the exact same switch as mine at Napa auto parts, and ended up just buying a small bulb socket that was for a taillight. The bulb doesn’t clip into the fixture like it originally did, but it does the job.
I was unsuccessful are Auto Zone and advanced auto parts, but Napa had a good selection.
I am a bit confused by your picture though, it seems that your light and switch are behind the rear plate of the fixture??
Edited by DanielM
Hey! Linda posted a link to buy a New old stock Bargman grab handle with the new lens cover! Perfect! All the Lens covers fit this. I installed mine just before I sold Grannie.
