what kind of gas line do use
I'm assuming your talking about the pilot light on your new water heater? You had to disconnect the old one from the gas lines, why are you not using the same pipes. Where did your existing gas lines go. Helps to explain a little more when asking questions
That really is not a do it yourself project to learn on the results could be disastrous. The location of the gas line unless it's the same make heater may not match.
