Boondockit Posted March 29, 2019 Share Posted March 29, 2019 (edited) Hi, I have a 1983 Minicruiser with only 65,000 on it, really clean and mechanically perfect... it has the recalled 5 bolt axel with the bonus fake duallys, as I understand it it is much safer, (if you are going to take your chances on the 1/2 ton recalled axel) to lose the foolies and go to singles on the back I went to a great heavy duty truck tire shop and the guy said that in order to swap out the foolies for singles that I need a wider footprint tire (8 or 10 ply) but my rims won’t work and that I couldn’t put a wider rim on the existing wheel unless I had one custom made which I’m not wanting to do is there any way to get singles in place of these foolies? Is he correct that I HAVE to have wider rims installed? Can I not just buy wider rims? Thanks Edited March 29, 2019 by Boondockit Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 29, 2019 Share Posted March 29, 2019 Road trip? https://www.facebook.com/marketplace/item/1128728803965667/ Quote Link to comment Share on other sites More sharing options...
fred heath Posted March 29, 2019 Share Posted March 29, 2019 43 minutes ago, Derek up North said: Road trip? https://www.facebook.com/marketplace/item/1128728803965667/ Talked to the owner on messenger. It has 6 lugs. Sounds like a great deal. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 29, 2019 Share Posted March 29, 2019 Just make absolutely certain that it's not a 6-lug 4x4 rear axle! Quote Link to comment Share on other sites More sharing options...
fred heath Posted March 29, 2019 Share Posted March 29, 2019 7 minutes ago, Derek up North said: Just make absolutely certain that it's not a 6-lug 4x4 rear axle! Same thought occurred to me. The carrier is more in line with the GO82 axle. I would ask to see a picture of the hubs before making a road trip. Quote Link to comment Share on other sites More sharing options...
Boondockit Posted March 29, 2019 Author Share Posted March 29, 2019 So these are true duallys? But still a 1/2 ton axle, won’t that still be a weak link for my 5000 pound Minicruiser? I thought the one ton is what is needed to avoid the “death axle” issue... Quote Link to comment Share on other sites More sharing options...
Boondockit Posted March 29, 2019 Author Share Posted March 29, 2019 Here are the hubs in Ohio Quote Link to comment Share on other sites More sharing options...
WME Posted March 29, 2019 Share Posted March 29, 2019 Well, I don't what the rest of things look like, but that's a 1-ton hub without an axle. Quote Link to comment Share on other sites More sharing options...
Boondockit Posted March 29, 2019 Author Share Posted March 29, 2019 (edited) thanks, are these rear ends pretty interchangeable? This is the Toyota that it’s coming off of, mine is obviously a Toyota but an 83 Edited March 29, 2019 by Boondockit Quote Link to comment Share on other sites More sharing options...
WME Posted March 29, 2019 Share Posted March 29, 2019 Possible problems The u-joint drive flange, the distance between spring perches, shock mounts, e-brake cable. Toyota actually had 3 different "kits" for the RV manufacturers to install Quote Link to comment Share on other sites More sharing options...
Boondockit Posted March 29, 2019 Author Share Posted March 29, 2019 Thanks, can I fabricate/weld and get around these things usually? Quote Link to comment Share on other sites More sharing options...
fred heath Posted March 29, 2019 Share Posted March 29, 2019 7 minutes ago, Boondockit said: Thanks, can I fabricate/weld and get around these things usually? Yes. Quote Link to comment Share on other sites More sharing options...
Boondockit Posted March 30, 2019 Author Share Posted March 30, 2019 Thanks Quote Link to comment Share on other sites More sharing options...
