Moved into a forest. The mice here hunt cats.
they literally use their own dead as food and nesting materials. Ate up my classic 86 burlap headliner and the smell o pee is legendary.
im fixing to gut the wall panels out down to the fiberglass but once done id like a surface insulation solution that can be painted on and looks decent. Spray foam is an idea..i wonder if i could coat it with white  bedliner
There was a guy here that did his roof with bed liner. You need the "bucket of death" to deal with the mice it is the only thing I have seen that really works!
Wife and I have been looking at foam based peel and stick wall panels; they would presumably add some ER value and being foam would not make noise.
has anyone else in here used this? I found a person that successfully used them in their RV closet.
 check this out:
https://rvinspiration.com/decorate/insulating-rv-walls/
