Filling ASME propane tank
markwilliam1
Went to fill my tank today. 1986 Granville. The only way to get propane into the tank was to open the bleeder valve if that’s what it’s called. When the valve was open it expelled lots of propane while the tank was filling up! Strong smell! Finally liquid propane came out the valve indicating a full tank?  I don’t remember having the valve expell propane before when opened. Is this normal?
Normal
Yes that is how it works when it spits liquid propane close the bleeder No Smoking!
Thanks Fellas! Had an almost empty tank but took only 8.5 gallons of propane to fill it. Is that normal?
The max SAFE capacity of a propane tank is 80%. So a "12 gallon" tank would be full at 9.6 gallons
