Yota Master Posted June 18, 2018 Share Posted June 18, 2018 Plan on installing a new Nav stereo upgrade with a backup camera, but still can't see much while driving out of the rinky dink factory mirrors. Any recommended aftermarket updates or has anyone done mods? Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted June 18, 2018 Share Posted June 18, 2018 (edited) not familiar with a 86 savannah travel, but if it is like most toys, you can put a bezel lens inside the rear window - I can see quite well out of mine. maybe some pictures of your ourside mirrors might help - mine has 2 mirrors on each side - one fisheye, one regular. Edited June 18, 2018 by DanAatTheCape Quote Link to comment Share on other sites More sharing options...
jjrbus Posted June 18, 2018 Share Posted June 18, 2018 There are You Tube videos on adjusting mirrors, may help if you have the correct mirrors. There are many thousands of these things running around with no mirror issues. Quote Link to comment Share on other sites More sharing options...
WME Posted June 18, 2018 Share Posted June 18, 2018 I used some flat stock steel and extended my mirrors out a couple of inches. I could actually see the side of the rv. With the convex mirror I could see the rear wheels a big help in parking. Quote Link to comment Share on other sites More sharing options...
jjrbus Posted June 18, 2018 Share Posted June 18, 2018 6 hours ago, WME said: I used some flat stock steel and extended my mirrors out a couple of inches. I could actually see the side of the rv. With the convex mirror I could see the rear wheels a big help in parking. Mine had a piece of square aluminum tubing for an extension on the passenger side. I removed it and tweaked the mirrors a bit and all was fine. Must be the model and types of arms that makes a difference? Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted June 20, 2018 Share Posted June 20, 2018 here is a front view on the mirrors on my warrior - I suspect they are stock. Quote Link to comment Share on other sites More sharing options...
