grahamr83
Funky Gas Readings?
I searched the forum for something similar, but wasn't getting the info I needed. (sorry if this is a repost).
I recently bought a 1986 Wanderlust with 22RE, and had the pleasure of taking it for a trip last weekend to camp with the family. On this journey i noticed that the gas gauge rose to just under a 1/2 tank when turned on, but didnt move from there during the whole trip (100kms). Additionally, the gas light came on at part of the trip and I threw in $20 of gas to get he home (right now in BC $20 gets you about 2 gal. :lol:)
So I'm curious about what could be causing this weird crossing of signals. Sending unit possibly? I'm going to get under the rig to investigate this AM, but not 100% sure what I'm doing, so just getting as much info as possible.
Also, my temp dial doesnt seem to work either, so i'll be investigating that too.
Check your grounds,especially under the dash.
twenty bucks for two gallons ?? OUCH!! joe from dover.
Temp gauge does not work at all or just funky? Do you own a 12 volt test light?
Temp gauge moves to just above "cold", but never higher or lower except when it's turned off. Dont have a 12V test light, but can get one easy enough. (and figure out how to use it.
A bit of an exaggeration. But right now its $1.50/L = $6/Gal.
Ok it's pretty easy. It will have a clip on one end the other a point. The clip goes on something metal (needs to be clean) the tip will connect to the wire on the temp switch (it's on the water outlet in the front of the engine) it will have a single wire remove it and stick the light prob in the end of the wire. Turn the key on and watch the test light it should blink slowly and the temp gauge will slowly rize until it reads full hot. It's the same drill for the fuel gauge but it will be hard to get to. If those tests work then the sensor is bad. With both misbehaving it is possible the voltage stabilizer is bad in the instrument cluster so be sure the test light blinks.
Sticker shock for Americans in Canada! At 3.8 liters to the gallon it mounts up pretty fast! I was in NB once during the $4 a gallon era and thought I was going to have to take out a loan to get home.
Edited by Maineah
High but not shocking to me. In American dollars that works out to 4.40 for an American sized gallon give or take. Here in northern Cal I am paying 3.69 a gallon.
Other than pulling the tank and replacing it, I have heard some people having luck with techron plus fuel system cleaner.  Might clean the sensor enough to get it to work again. Add twice, 2 fill ups.
Back in 2008 I did a road trip to Yellowknife, Northwest Territory, GAS was $7.48 Canadian for 4 liters. Had a $96.00 fill up.
Darrel
