SSBreeze Posted April 3, 2018 Share Posted April 3, 2018 I am looking for any info on the blower fan motor. Mine just has one speed at the moment, high. When turning the knob at any position, the fan only blows on high. 1983 21' Sunrader. Any info for replacement or repair ideas would be great. Thank you. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 3, 2018 Share Posted April 3, 2018 Assuming you mean the cab heater fan, you've got classing symptoms of a defective 'resistor pack'. https://www.rockauto.com/en/catalog/toyota,1983,pickup,2.4l+l4,1277197,heat+&+air+conditioning,blower+motor+control+module+/+resistor,6557 Not an '83 but probably similar:- Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 3, 2018 Share Posted April 3, 2018 Actually, having thought about it a bit more, I've a couple of questions:- Is the Sunrader new to you or have you had it a while? Is this a new problem? Worked before and stopped? Also, confirm it blows Full no mater the switch position? Is there an 'OFF' position on an '83? Still blows Full? Got a multimeter? Normally when there's a Resistor Pack problem it'll only blow Full in the Full position or as in the case of the video, 3 & Full. And I'll repeat what the guy said in the video. These things get HOT. Like hot enough to brand yourself HOT. That's why they're installed in the ductwork, to cool them. Quote Link to comment Share on other sites More sharing options...
SSBreeze Posted April 3, 2018 Author Share Posted April 3, 2018 Yes, the cabin heater fan...sorry for lack of info. I have had it about 3 months now. It was working in 2 speeds since I got it. Since it is still cold here in the PNW I didn't want to take it apart just yet as I still get defrost/heat on high. Yes to the multimeter. There also appears to be a google ad that is covering most of your second reply. I cannot read after "confirm it blo"... and "Normally when ther"...Thank you for the info. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 3, 2018 Share Posted April 3, 2018 32 minutes ago, Derek up North said: Also, confirm it blows Full no mater the switch position? Is there an 'OFF' position on an '83? Still blows Full? Normally when there's a Resistor Pack problem it'll only blow Full in the Full position or as in the case of the video, 3 & Full. And I'll repeat what the guy said in the video. These things get HOT. Like hot enough to brand yourself HOT. That's why they're installed in the ductwork, to cool them. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 3, 2018 Share Posted April 3, 2018 Quote Link to comment Share on other sites More sharing options...
SSBreeze Posted April 3, 2018 Author Share Posted April 3, 2018 Yes, it blows full in 1, 2 or 3 position. Fan does turn off when put in off position. I will check it first with meter, then replace as needed. Thank you, much appreciated. Quote Link to comment Share on other sites More sharing options...
Maineah Posted April 4, 2018 Share Posted April 4, 2018 I would have a look at the resistor I have seen them break off inside and basically short the entire thing to max. Does the switch "feel" OK like click into place? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 4, 2018 Share Posted April 4, 2018 Can't say I've ever experienced that, but certainly possible that it's shorted across the resistor pack. Those would be the symptoms. Every time I've had a resistor pack problem, it's always been Off, Nothing, Nothing then Full Blast! Quote Link to comment Share on other sites More sharing options...
SSBreeze Posted April 4, 2018 Author Share Posted April 4, 2018 Yes the switch feels fine and solid. Will check that also. Thank you. Quote Link to comment Share on other sites More sharing options...
fred heath Posted April 4, 2018 Share Posted April 4, 2018 1 hour ago, SSBreeze said: Yes the switch feels fine and solid. Will check that also. Thank you. Not blower related but what are you running for a rear axle? Quote Link to comment Share on other sites More sharing options...
SSBreeze Posted April 4, 2018 Author Share Posted April 4, 2018 I have the 6 lug 1 ton floating. Just replaced rear drums, shoes and 4 seals. Quote Link to comment Share on other sites More sharing options...
fred heath Posted April 4, 2018 Share Posted April 4, 2018 46 minutes ago, SSBreeze said: I have the 6 lug 1 ton floating. Just replaced rear drums, shoes and 4 seals. Nice looking rig. Quote Link to comment Share on other sites More sharing options...
SSBreeze Posted April 5, 2018 Author Share Posted April 5, 2018 Thank you. I'm going to post some interior pictures as my project moves along under a different heading. I put in 4 lodge poles and hang 2 hammocks now. Quote Link to comment Share on other sites More sharing options...
SSBreeze Posted April 6, 2018 Author Share Posted April 6, 2018 Update...replaced the Blower Motor Resistor and fan is running 3 speeds again. Appears that the tiny coiled wire was broken and folded over on itself, causing it to blow one speed only. Thank you so much for the info! Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 6, 2018 Share Posted April 6, 2018 Good news. Thanks for the update, closing the circle. Quote Link to comment Share on other sites More sharing options...
