ToyoGuy Posted December 18, 2017 Share Posted December 18, 2017 Can anyone comment on how much loss (if any) there is running the coach shore plug into the generator output plug (and thus through the coach distribution panel) vs using the hardwired charging cables available from Honda that just plug into the generator output plug and clip straight to the battery posts? Someone told me there is some loss associated with plugging into the generator with the shore plug and going through the whole system. Thanks for any insight. BR, TG Quote Link to comment Share on other sites More sharing options...
WME Posted December 18, 2017 Share Posted December 18, 2017 This is a non-issue issue. The Honda would charge your battery at what ever rate it wants. Plugging in the RV power cord brings your converter into the picture and, with a newer converter, it will be better for your battery. Quote Link to comment Share on other sites More sharing options...
Maineah Posted December 19, 2017 Share Posted December 19, 2017 5 hours ago, ToyoGuy said: Can anyone comment on how much loss (if any) there is running the coach shore plug into the generator output plug (and thus through the coach distribution panel) vs using the hardwired charging cables available from Honda that just plug into the generator output plug and clip straight to the battery posts? Someone told me there is some loss associated with plugging into the generator with the shore plug and going through the whole system. Thanks for any insight. BR, TG OK for a quick charge of a dead battery but lousy as a charger it is very poorly regulated plug the camper cord in. Sure there is a little loss but it's better than buying a new battery. Quote Link to comment Share on other sites More sharing options...
ToyoGuy Posted December 19, 2017 Author Share Posted December 19, 2017 Thanks guys, I'm glad I bought the Progressive Dynamics converter with the conditioning cycles for charging the battery. BR, TG Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted December 19, 2017 Share Posted December 19, 2017 if you do decide to connect directly to the battery, I would disconnect one of the battery terminals - back feed from the charge can screw up a power converter..... Quote Link to comment Share on other sites More sharing options...
