LarryOswald Posted October 28, 2017 Share Posted October 28, 2017 (edited) We found is a possible deal for the right person. It is a 1984 Coachman needing work, with lots of positives at a give away price, $1000. It has been sitting a couple years due to needing a clutch, NAPA parts included. It has only 31K miles and the story makes sense. The drive train is the four cylinder 22R four speed standard. Engine runs well having had some gaskets replaced. It needs an exhaust manifold gasket. The six tires are new. The driver's cockpit and upper sleeping area are clean. Seats are good. There is a driver side rear cabin leak that is pulled apart, fairly messy. Above the driver's entrance there is molding loose. There is some surface rust bumpers, rims although I did not look underneath. Windshield is cracked but tight. I do not know what works in the cabin. It is listed in Hartford CT Craigslist. I am not the seller ... just the matchmaker. Call Russ. Try to leave a message and he hopefully will get back to you. This is a deal if you are handy and interested. Larry Oswald https://hartford.craigslist.org/cto/d/toyota/6357008330.html Edited October 28, 2017 by LarryOswald typos Quote Link to comment Share on other sites More sharing options...
fred heath Posted October 29, 2017 Share Posted October 29, 2017 If it has the 6 lug ff rear axle it might be saleable. If the 5 lug "foolie", probably best for parts. Quote Link to comment Share on other sites More sharing options...
